Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
help with installing coilovers on rear, custom install experience welcome.
Old 03-06-2015, 09:46 AM
old_blue1 old_blue1 is offline
old_blue1 is starting off with a positive reputation.
I have decided to four link my rear end and use coilover springs. I need assistance in how these are installed as far as under compression/preload and how much. The bed will be off the truck so I know the added weight will compress the shocks a little bit I am trying to figure out how much preload the shocks will need. I am assuming at ride height these are at full extension as you would need some rebound shock for when the vehicle goes over speed bumps or high spots.
Anyone with experience let me know what you did and experience. I have never worked with coil overs before so I am a little green in this area.
Old 03-06-2015, 09:54 AM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon has a very good reputation on FTE.Gicknordon has a very good reputation on FTE.Gicknordon has a very good reputation on FTE.
gicknordon
I used the ridetech setup guide to choose spring rates. They generally say that with a threaded shock body, you want the adjustment collar close to center, and same with the shock. You want the shock to be pretty close to the center of its travel at ride height. This is because the suspension not only compresses, but it also extends from ride height, and you dont want the shock to be the limiter on suspension travel.
__________________
Nick Gordon
1997 F-350 crew cab long bed 7.3 powerstroke (totaled but getting fixed)
1988 ford thunderbird turbo coupe
1948 F-1 project 429 big block
Build thread for 48 http://www.ford-trucks.com/forums/11...9-ford-f1.html
Photobucket album for 48 http://s1137.photobucket.com/albums/...don/49%20ford/
Old 03-06-2015, 10:55 AM
Thanks for the quick reply and explanation. That was what I was referring to but I couldn't find the words. Basically I didn't want tk rear end to kick up like a mule because the shocks would full extend going over a bump.
Old 03-06-2015, 11:37 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to beholdAXracer is a splendid one to behold
Chuck Frank
Bottoming out a shock at either end of the travel can permanently damage the internal valving. The suspension should always have mechanical stops that prevent the shocks from bottoming out at either end. Do not remove the bump stops to gain travel or lower the vehicle, contact between axle and frame can cause severe damage and/or loss of control. Also the coilovers should not be installed vertically unless you are building a drag race only chassis. I'd want at least 4" of shock/suspension travel in either direction from at rest position.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
Old 03-06-2015, 12:59 PM
Last chance 53 Last chance 53 is offline
Last chance 53 is gaining momentum as a positive member of FTE.
Installing coilovers
On a streetrod type truck, As in something you are not hauling heavy loads, I would set it up with a 5'' stroke shock. With about 2/3rds of that for compression. Most shock builders will give you a install length. I use ridetech shocks and have had good luck with them. I would put about 1'' of preload in the spring. Hope this helps.
Old 03-06-2015, 10:31 PM
Awesome. Thanks for the great information.
Similar Threads
The saga of the new shocks... Rifboy 2009 - 2014 F150 9 05-09-2014 07:48 PM
How to position rear upper coil-over mount/crossmember? jamieson48 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-07-2012 02:58 PM
Shock and Strut Install - Done! tom87 2004 - 2008 F150 6 06-23-2009 07:07 AM
More info about shocks than you want to know. AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 50 04-09-2009 10:58 AM
Advice on installing front coilovers. tim1234 Expedition & Navigator 0 02-14-2009 05:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
