repeated alternator failure
Hey all I need some help on this one. I've got an ambulance that keeps eating the alternators up. The batteries are new upgraded grounds and all that goodness. Problem is that every 3 months or less the alts fry. I've tried the DC power alts as well they last about 6 months, ford gone in 3. All the wiring harnesses are good with no breaks or chafing. Even went as far as checking the fuseable links in the harness. Anyone e have a suggestion as to wear or what else to check. Outside of the alternative going out engine and all other systems are perfectly fine.
Altogether I have 12 ambulances and 5 brush trucks that I maintain all have the dual system on them. There set up exactly the same way. This is the only rig I'm having this issue with. Any and every update and upgrade that's out has been done to them. Just haven't gotten this 1 rig to keep its charging system to stay together.
my understanding is that the PCM selects and controls which alternator is on during the glow plug on phase of engine start up, then controls which alternators are on - one or both - in response to load. I can see a scenario where only one alternator is being switched on at a 90 amp load, and that is pretty high for just one alternator continuously.
Brian
Brian
Yes they are pcm controlled. Just finished replacing the failed alt and charging the batteries up. It's now on the way to dealership (which sucks by the way ) for a pcm update if needed. As of now everything is working like it's supposed to be. I'm thinking with that many failures happening it has to be a pcm controller problem. I'll keep you posted as to what I find out
