01 f250 loses power and runs rough
Old 03-06-2015, 03:31 AM
oliebeme's Avatar
oliebeme
oliebeme is offline
Angry 01 f250 loses power and runs rough
My 01 f250 starts and idles fine but after driving it just a little while it starts running rough and the check engine light comes on. When I checked for codes it shows p0307. My Chiltons manual says it is cylinder 7 misfire but it acts like it is only running on half the cylinders. A mechanic my wife talked to said it might be 1 of the boards are bad. What board is he talking about and could it be the pcm?
I am just a backyard mechanic and don't know much about these newer vehicles and all the electronics. Any Ideas what this might be?
Old 03-06-2015, 04:14 AM
Tugly's Avatar
Tugly
Tugly is offline
If you at least know how to check resistance with a meter, you came to the right place. The UVCH link in my signature has a good place to start.
Old 03-18-2015, 06:02 PM
oliebeme's Avatar
oliebeme
oliebeme is offline
I checked the resistance and it didn't show any resistance on any of them.
What might that mean?
Old 03-21-2015, 01:56 AM
oliebeme's Avatar
oliebeme
oliebeme is offline
I looked at the link and it shows the 42 pin connector. Is that what I should be checking the resistance on, or is it the 9 pin connector on the top side of the valve cover? Do you need to take the valve cover off to check the 9 pin?
Old 03-21-2015, 06:02 AM
Tugly's Avatar
Tugly
Tugly is offline
The 42-pin tests the connections from that point, through the outer 9-pin, the inner 9-pin, the injector coils and connectors, and back. No resistance, or no conductivity?
Old 03-21-2015, 10:22 AM
HD Rider's Avatar
HD Rider
HD Rider is offline
oliebeme: If you want you can call me and I'll walk you thru the test. I'm not busy today anyway. 406-939-0177
trike1946
33
04-09-2014 08:05 AM
zigzkidz
13
08-06-2012 08:18 PM
scottcox
15
03-13-2010 08:40 PM
molamo
03-31-2009 06:33 PM
250f4life
03-01-2009 06:00 PM
Quick Reply: 01 f250 loses power and runs rough
