1997 F250 HD 460 towing cam and heads
I am doing some upgrades to a 1997 F250HD 4x4 with a 460. I use this truck primarily for towing a 5th wheel. The engine is stock W/EFI and I have added MSD ignition box and coil, K&N Filter, 3" exhaust. I have a head gasket issue so I figure that I may as well do some upgrades while I have the engine open. I was planning on upgrading the heads and need suggestions on heads, cam and headers.
Another note - It is an Arizona truck without a smog requirement.
Get a hold of Scott at Re in"Car"nation High Performance - Home this guy specializes in these engines and will get you a custom ground cam that works better than any off the shelf cam. Also does head work and has a line of performance heads.
Ben_E
10-22-2015 07:31 PM
velcro7279
10-31-2006 08:19 PM
BBF250
09-12-2005 03:34 PM
peepinu
02-23-2004 09:18 PM
cjcathey2002
08-13-2002 09:02 PM
