1952 F6 "Virginia" build thread
#32
a bit of progress
Although I haven't posted in awhile, I have made some progress.
I went to North Carolina and spent a couple weekends with AXracer. Not knowing how to make patches for these fenders, I took his class last April and went back last weekend to do more work.
First, if you don't know how to do these patches, meeting up with AXracer is definitely worth it. I learned a lot, and although I am far from an expert I think I can now do these patches by myself. I may still go back again for help with finishing the seams, and body filler, etc.
Anyway, here are a few pictures. Patches are tacked in and I need to finish welding.
The Fender had leading in it
Preparing to cut out the bad part
All cut out
We cut the doubler off. Welding in the new doubler
New doubler installed
Starting to make the patch
Bending
More bending
Patch held in place. Scribing a mark in the black area for final trimming
Fits good - time to weld
Tacked in
My son went as well and did some of the welding. This was the primary reason for buying the truck - to expose him to some of this work.
All cut out
Bending
More bending
Tacked in
#33
bottom portion of the fender
Here are some pics of the bottom portion of the fender where the running board bolts.
Again, thanks to AXracer for the help.
The damage
Making the tracing to use to make the forms
Making the forms
The patch inside the form
Bending it. The curved portion took more persuading...
Cut slots to get the curve. Will weld these up later.
Using the shrinker to get the bend to fit the panel.
Unfortunately I don't have a picture of the patch tacked in place. I took a bunch of video so I could remember how to do it, but guess I stopped taking pictures.
#34
Too bad you didn't take any stills of the two lower patches tacked in place and showing how we finished the J roll and made new doublers.
As Steve said, he took my workshop last April when we made the patch for the area where the upper and lower sections bolt together. Steve then contacted me and we set up a private 1 on 1 class for him and his son last weekend where we made the two lower sections shown above.
#35
Twitchyleprechaun
10-31-2016 07:41 PM
farmall_7
01-13-2016 01:13 PM
