1952 F6 "Virginia" build thread
Old 05-04-2015, 02:21 AM
48/51F1's Avatar
48/51F1
48/51F1 is offline
I cut the nose off and put on my f1 fenders shortly after that pic. I've got a radiator for that 8ba too, and some running boards and rear fenders if you need em.
  #32
Old 01-23-2016, 03:19 PM
wardsd's Avatar
wardsd
wardsd is offline
a bit of progress
Although I haven't posted in awhile, I have made some progress.
I went to North Carolina and spent a couple weekends with AXracer. Not knowing how to make patches for these fenders, I took his class last April and went back last weekend to do more work.
First, if you don't know how to do these patches, meeting up with AXracer is definitely worth it. I learned a lot, and although I am far from an expert I think I can now do these patches by myself. I may still go back again for help with finishing the seams, and body filler, etc.
Anyway, here are a few pictures. Patches are tacked in and I need to finish welding.
The Fender had leading in it
Preparing to cut out the bad part
All cut out
We cut the doubler off. Welding in the new doubler
New doubler installed
Starting to make the patch
Bending
More bending
Patch held in place. Scribing a mark in the black area for final trimming
Fits good - time to weld
Tacked in
My son went as well and did some of the welding. This was the primary reason for buying the truck - to expose him to some of this work.
  #33
Old 01-23-2016, 03:36 PM
wardsd's Avatar
wardsd
wardsd is offline
bottom portion of the fender
Here are some pics of the bottom portion of the fender where the running board bolts.
Again, thanks to AXracer for the help.
The damage
Making the tracing to use to make the forms
Making the forms
The patch inside the form
Bending it. The curved portion took more persuading...
Cut slots to get the curve. Will weld these up later.
Using the shrinker to get the bend to fit the panel.
Unfortunately I don't have a picture of the patch tacked in place. I took a bunch of video so I could remember how to do it, but guess I stopped taking pictures.
  #34
Old 01-23-2016, 05:16 PM
AXracer's Avatar
AXracer
AXracer is offline
Too bad you didn't take any stills of the two lower patches tacked in place and showing how we finished the J roll and made new doublers.
As Steve said, he took my workshop last April when we made the patch for the area where the upper and lower sections bolt together. Steve then contacted me and we set up a private 1 on 1 class for him and his son last weekend where we made the two lower sections shown above.
  #35
Old 01-23-2016, 08:04 PM
OneOffStroker's Avatar
OneOffStroker
OneOffStroker is offline
I really don't mean to thread-jack, but I'm in Virginia Beach, about 3.5 hours from you. I'm a little bit interested in these workshops you put on. Do you have a thread or post with some additional info/dates for upcoming workshops?
  #36
Old 01-24-2016, 07:43 PM
pweng1's Avatar
pweng1
pweng1 is offline
Its great to do these things with you son. These trucks are magic when it comes to bonding generations.
SeaCarr
08-19-2017 02:04 PM
Twitchyleprechaun
10-31-2016 07:41 PM
coopdog76
17
04-23-2016 12:52 AM
farmall_7
01-13-2016 01:13 PM
gr8scott72
06-29-2009 08:10 AM
Quick Reply: 1952 F6 "Virginia" build thread
