Most useful Shop Equipment?
#31
Most important of all: Eye & hearing protection!!!!!!!! Take it from someone that has damaged hearing after too much noise in the garage. I wear the ear muffs for everything remotely loud to try & save whats left of my hearing. Goggles are always on if there is any chance of anything flying. Eyes don't grow back!!!
Mig welder of course.
4 1/2" grinders, I have 4 of them. One with a wire wheel, one with sanding disc, one grinding disc, one cutoff wheel. No more changing accessories constantly, I just switch grinders.
I bought a couple of masking gadgets, the ones that put the masking tape on the paper as you pull it off. Two different widths of paper, LOVE them! So much better than using newspaper! Got 'em at the flea market, 3M brand, $5.00 each, loaded with paper!
#32
Concrete floor, then a creeper and roller chair, followed by over head cover, then followed by walls. A very secure way to lock up any and all tools.
My likes are a easy to grab small tool bag/socket set with a 1/4 dv ratchet and reg and deep set sockets up to 7/16. And another with 3/8 dv ratchet, again with reg and deep well sockets.
Assortment of to 15/16-1/4 to 1" combo wrenches. and always a couple extra 3/8 thru 9/16 wrenches. 1/2 dv ratchet set for the big stuff, is always nice.
Having a bunch of tools does not matter, but having just the amount needed to do what you have too, does. Quantity does not beat quality. Quality tools last longer, that is why they cost more. And that results in less stripped hardware and less busted knuckles.
But I do shop at Harbor Freight too. One adjustable wrench is NOT a socket set, but a great way to strip some nuts. Then what, vice grip time....and a good pair of vice grips.
If you have air, and air ratchet is a time and effort saver and makes for a quick disassemble of stuff with lots of nuts and bolts. Also a great way to pinch your finger between the end of a wrench and a what ever the air ratchet spins the wrench into.
A drop light.... plug in or battery, battery one that matches a Dewalt set of 19V with a drill, sawzall, skill saw, 4" grinder. "Red Diablo" sawzall blades, better than a hot buttered biscuit.
Get what you need and use alot, rent those nice to have, but do not use enough to warrant buying it. Ball joint press, a tie rod fork, steering wheel puller. Build a good quality base set of tools and then MARK them. I use highway road worker day-glo orange or green. And or a Ford blue spot, but easy to ID makes for a better day.
#33
I don't need a Beer Fridge so that saves floor space, just a Coffee Pot on the counter. Also the Coffee Filters are way better than Band-Aids as the white ones help to stop bleeding and scabs will not adhere the coffee filter to you so it just comes right off with reopening the wound, apply with a little tape. After having to pay a $1,400 ER bill for them to take a Dremel to my Eyeball after 3 days of me trying to scrub it out myself... I wear safety glasses. Music is covered.
I should have mentioned that safety items are important, however I thought that would be obvious. Multiple extinguishers, something to clean wounds and and stop bleeding, Saline Solution to spray out eyes also a Shot Glass is perfect for Saline and sealing around your eye socket (don't use if it has trace amounts of alcohol), plenty of Floor-Dry (kitty litter works too), Jack Stands are both a Tool and a Safety Item.
I need to pick up a cheap computer for internet access when I need to reference all the great information on this site and others. I have a HUGE library of automotive reference materials and am always looking for more.
The home we are renting is owned by a Plumber who remodeled with the intent of staying there till they had an "oops" baby and out grew it. So I have nice bonus items like Cold and Hot hose bibs outside and water running in the shop.
I'd have to say that the tool I like the most currently is my Pressure Washer, it makes every job easier/nicer when it's clean, I usually spend more time Under a vehicle washing it that cleaning the outside. It's also very versatile in that I can clean the vehicles, shop floor, driveway, house, roof etc etc etc
#36
Assortment of to 15/16-1/4 to 1" combo wrenches. and always a couple of 3/8 thru 9/16 wrenches. 1/2 dv ratchet set for the big stuff, is always nice.
That is an impressive list
#37
Very true. I bumped my head, my friend took me to ER, they put 7 staples in my head with zero pain killers because I smelled like beer. Then I walked to the closest bar and called my friend to pick me up and the bartender saw my papers from the hospital and my shirt soaked in blood and refused to serve me because he thought I was on meds!
#38
That is not even a scratch on the surface of what I have. I inherited all my dads tool and guns when he passed away.
220 stick welder, 110 Craftsman wide feed, big bottle victor gauge torch set, 1/2 and 3/4 drive ratchet socket sets. Lots of air tools, hand tools, test equipment, hub socket both type, gear pullers, tie rod forks. Gravity metal band saw, 2 14" chop saws.....2 drill presses.
"Estate sales" and Auctions old automotive shop closing down are a great way to get some good "old" tools.
#39
#40
Now that's funny right there!! When ya really want a drink!!
Yep, stitches or staples w/o painkillers,,, sooo not fun!!
Oh,,, I am jealous of your shop, AND 2-post!!! SWEEET!! Nice score!
#41
This thread went south,LOL. The OP asked about what every ones opinion was on most use full tools, turned into well i have this and that.lol Guess its my turn, i down sized because of back issues i can not build like i use to,sold my fab/chassis table,shear,54" slip roll, and 1 of my tig welders. My most use full is my 2 post hoist, best thing there is having back issues. Most of my tools i dont use much anymore but i can build about anything from metal and wood, there nice to have just incase but in the next few years im gonna have a heck of a tool sale. Maybe a thread showing our own personal shops, not where we work or our buddies but at our homes.
#42
I will happily update with progress photos of the shop I just got and as I outfit it.
Yes, a 2 post post lift would be lovely, I also blew 2 of the disks in my Lumbar a few years ago. They come up on CL pretty often but I don't have the ceiling height to utilize one unfortunately. I have worked in multiple shops with lifts and they are worth their weight in gold, especially for someone who's injured.
I don't mind seeing other people's shops. It's beneficial for seeing Layouts, what collection of tools works for the work I see people do on the site and I respect a well organized/clean environment as I am **** about that and with multiple Shared-Shop arrangements the last few years with people who could care less.... I can't wait to clean and setup all my tools, part of why I want to prioritize a list of what is useful so I can account for the sizes of the equipment and make my shelf heights and cabinet placement accordingly.
Truck ****, Shop ****... all the same to me. haha
#43
I can relate to being physically challenged and not being able to lift past my waist. I'm rebuilding my large shelter currently and putting a track system into my wonderfull crushed gravel floor. Then its time to finally build this gantry system I've wanted for the last year. Its going to be cable operated from the A frame through under the tracks to the other end of the A frame. Made a long list of cons and cures this last winter and I figure most of the bugs are worked out. Will find out in a month or so, its project 5a, 5b is rebuilding the shop.LOL
PS. I got a ton or 2 of "stuff" / crap.
#44
Make a place in the floor along the wall opposite the door to put a Hazard Fraught Tools winch mount and winch. Use that to pull vehicles inside. If you have a place to mount a ****** block outside you can use it to pull the truck back out without moving the winch.
Put the air compressor outside in a seperate room/shed.
An old office chair works as a roll around stool, more comfortable too.
Instead of a hamper, get an approved oily rag can. They can generate heat and combust.
Fire sprinklers.
Go-Jacks, wish I had a set.
Top side creeper. I plan to buy one for work, maybe one for home.
Good dial back timing light with tach.
Exhaust hose. CO kills.
Mobile welding shields. Pieces of plywood with stands work. Keeps the unsuspecting from getting flash burns.
Fire sprinklers.
#45
Maybe my favorite tool is an 18 volt cordless impact. Small enough to get into tight places and powerful enough to break bolts loose. I actually used it last time I worked on rusty exhaust manifold bolts. Removed a few , what it wouldnt get the air did. It is perfect for this because it wont break them but will sometimes break them loose. And you dont have to drag an air hose out. Pack it with you when you go 4 wheelin or a road trip. Just keep batteries charged and you are good to go.
