Hand Throttle
My manifold has the same pin as in the picture which is the pivot for the lever as seen in the photo. I just don't have the outside lever which would connect to the throttle cable. I'll need to see if the existing lever has the tab on it that the throttle lever pushes against to open the throttle. If I remember, I'll check it in the morning (truck is in the barn).
Similar story for me as a kid. My Dad had a 48 Chevy 3/4 ton. It had the hand throttle and a granny gear. Dad would set the throttle and put it in gear and I would carefully let out the clutch while Mom, Dad, and older brother and sister would pick rocks from the field or pick corn in the fall.
In the 53-56 models the hand throttle was standard on F250's and up. It was an option on F100's.
Not doubting you, but where did you hear about the F250's and up having manual throttles being standard? My truck has two holes in the dash (for cigar lighter and throttle) but they both have the exact same type of push in silver cover that fills the holes, and since my truck isn't a custom cab truck, I had to figure both were put in at the factory.. Could've easily been done when he got the carb replaced at some point that they deleted the throttle, but how did they get them to match, and why would they care enough? Man, I'm thinkin so hard on such a minor detail... The disease must be progressing faster than I thought! :P
Here is my corrected info: hand throttle was optional on F100 and F250's. They were standard on F350 and up.
Thanks for questioning this. Now I am more accurate myself.
And its no hurry, I was just curious, as I had a hole in my dash, and was thinking if I owuld go the hand throttle route or just cover it up.....
Might you have any pictures of the push in silver covers??
I haven´t decided what route to go for??
I'm about to head out on a plane to AZ, but this has one of them in the picture, sorry for the mobile link, but it should work, I hope. http://s1383.photobucket.com/user/fladoodle/media/My%201954%20F250%20Project/DSC01889_zps183bc1cc.jpg.html?sort=3&o=137
WarWagon85
06-28-2017 09:09 AM
abe
05-02-2016 01:28 PM
