When you put a 1975 front end under a 1965 f100,Do you keep the 1965 springs or use the newer springs from the 1975 truck you got the I beams out of?
Thanks Russ.
Did the 75 have the same engine as your truck? When I did mine I bought new springs, and they wanted to know what engine, trans, and did it have air, so I guess it all is related. Plus how weak are your springs? All this is food for thought. Good luck
