Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
SPONSORED BY:
Click HereAdvertisement
Easier way to install 2.5 inch leveling blocks
Old 03-03-2015, 11:25 PM
FX-4 Man's Avatar
FX-4 Man FX-4 Man is offline
FX-4 Man is starting off with a positive reputation.
Wanting to install 2.5 inch leveling blocks on my 2005 F-150, from all I've seen online, I'd need to take loose the top ball joint, et al, etc. just to slide the blocks into position.
Question I have is, would I be able to just disconnect the shock mount at the lower control arm and angle it away so I could slide the blocks in place?
Gonna have to wait for warmer weather anyway and would just rather not have to pay somebody to do so simple a job (my Dad checked a shop near him, they wanted $200 not including realignment).
Any help or advice would be greatly appreciated.
Thanks, Doug
Old 03-04-2015, 07:58 PM
Charlescuster6969 Charlescuster6969 is offline
Charlescuster6969 is starting off with a positive reputation.
Call me 5126351342
I'll explain
Old 03-05-2015, 06:17 PM
iamrfixit iamrfixit is offline
iamrfixit is starting off with a positive reputation.
Just put a 2.5 kit on my son's 2006.
Not disconnecting the upper ball joint will NOT make this job easier, more likely all but impossible. You need to get the top of the strut completely out because you need to bolt the spacer to the top of it. The only way to really accomplish this is to disconnect the upper ball joint, sway bar bracket and tie rod end. I prefer to just pull the lower strut bolt and completely remove the strut.
Getting the ball joint separated is easy, usually pops right apart with no special tools. Just loosen the nut until it is finger tight, this will catch the knuckle so it doesn't fall apart. Then strike the steering knuckle from the rear side, right on the joint. A couple hits is usually all it will take. You are hitting sideways, not downward.
If it's being exceptionally difficult; hold the head of a 3lb hammer against the back side of the knuckle, right at the ball joint and hit the opposite side of the knuckle, again right at the ball joint. This will cause the tapered joint to compress ever so slightly and the ball joint stud will literally pop right out of the knuckle. I have NEVER had this not work. You definitely don't want to use a pickle fork to separate it unless you plan to replace the ball joint.
The whole job is very easy, took me about 15 min per side, with the luxury of a warm shop, air tools and a good floor jack.
Old 03-05-2015, 10:11 PM
FX-4 Man's Avatar
Thank you sir, now all I have to do is wait for.........(next week apparently, in the DC metro area), highs are supposed to be in the low to mid 50's, (already have the floor jack), I think I can make do with hand tools.
Similar Threads
***Old Doug Thorley header catalog???*** AerostarDad 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-10-2013 06:01 PM
Doug Nash OD? danlee Clutch, Transmission, Differential, Axle & Transfer Case 0 07-15-2011 08:38 PM
V8 gasser outlifts V8 diesel high ho silver Super Duty & Heavy Duty 3 04-11-2007 10:20 PM
Need help with 94.5 PSD no start... Doug9213 1994.5 - 1997 7.3L Power Stroke Diesel 2 12-08-2006 12:10 PM
Woops! Need new rear slide window dougg 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-17-2001 08:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
