Tire TPMS light will not go off
When you say the light won't go off, does it flash or on constantly? Did you check your owner's manual to a possible solution?
Possible causes from 2015 Manual light on solid
Tire(s) under-inflated
Spare tire in use
Tire pressure monitoring system malfunction
Tire rotation without sensor training
Light flashing
Spare tire in use
Did you recently have new tires installed or a flat fixed where the tire was removed from the rim?
Did you recently acquire and start to use a new or different cellphone charger?
Spare tire in use
Light flashing
Spare tire in use
Back tires are 80 psi and the front are 65 psi.
Did the the light come on and then you added air?
On page 364 of the manual it will tell you how to perform a TPMS reset.
Last Monday Texas had a brief ice storm . I was responding to a MVA early that morning and the light came on . This same thing happened during the last time we had snow but went out after a couple of days . I did add about 5 psi to each tire . Will bring them all up to 80 psi and try that . Thanks for all the info. First time to post .
I added about 5 psi to each one after the light came on but did not bring the rears to 80 psi . Will do that in the morning before I leave for work . We are suppose to get more sleet & snow tomorrow afternoon . Hopefully this will get reset . Wow 2 weeks in a row in Texas with winter weather .
You will have to drive a bit to have the light go out. I have 70 psi in the rear tires when not loaded and 65 psi in the front tires all the time. I program my tires for 65 psi all the time.
I see the newer models even tell you what tire is low. I use the phone App, Torque Pro and it tells me the pressure of each tire.
This has been my understanding that the power to the sensor comes from the tire spinning....
when I went to 37" BFG's on factory rims on my 2012 If I remember the tires were 50 psi and light stayed on all the time.. bought a sheet of black window cling and cut out a clean quarter sized circle and stuck it on the cluster lense to block the light... then when I was at dealer on day they did a reset to 50psi and problem solved
