Compression test question
So I tried to do a compression test on my 6.9 for the first time and found I need some clarification. When people say cranks, do they mean compressions or turns of the crankshaft? On other words, would four cranks be four compressions or would it be two compressions?
Also, how many compressions do you all do when compression testing an engine?
As for the results I got, I only did half the cylinders (1,2,7,8), at four compressions most of them went to 450psi (#2 was only 400), at 5 most were at 470-480 (#2 was at 420)-430 and at six or seven most were at 490 or 500 while #2 was at 450. This was with a warm engine but only the glow plug being tested removed.
Received 3,090 Likes
on
While like tom says thats within spec, there is something different going on in that cylinder. Was this warm or cold? On a warm engine i would think you should see peak compression after 3-4 revolutions.
IE i compression tested my datsun, got like 75 , then 90 then 95 without going higher with more cranking.
Did you pull the glow plugs or injectors of all cylinders?
dieselaholic
07-13-2011 12:52 AM
viperrtblck
06-19-2006 07:30 PM
