'88 F150 4.9L engine into '89 F250
Good morning FTE,
I currently have an '88 F150 4.9L M5OD 4x2 truck. I am considering picking up an '89 F250 5.0L ZF5 4x4 truck from a friend and swapping the 4.9 into the F250. I'm trying to compile a list of things I'll need/need to do to complete the swap. I've done lots of searching but it seems most folks go the opposite direction (which is fine). I'll have both trucks side-by-side so I'm hoping this will be relatively painless.
Are the shock towers the same size on both trucks? I know I'll need to move the motor mounts to the F250, the computer from the 4.9, and redo the exhaust. Anything else I'll need to be concerned with?
Thanks for any help you can provide!
3BadBirds
11-19-2007 11:27 PM
