Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-23-2003, 07:01 PM
dustof45 dustof45 is offline
dustof45 is starting off with a positive reputation.
door lock cylinder
How do u get the door lock cylinder out of a 45 ford 1/2 ton pickup? ive tried about everything and it doesnt seem to budge.
__________________
Dustin
1945 Ford 1/2 ton in restoration process
  #2 (permalink)
Old 07-23-2003, 09:22 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
door lock cylinder
Suposivly there's a screw that you can reach from the side and the thing will come out. I've never gotten mine out though.
Clayton
  #3 (permalink)
Old 07-23-2003, 09:37 PM
door lock cylinder
yeah i see there is something thereon the side, but i cant recognize what kind of screw head it has on it.. what did u do since you couldnt get yours out?
__________________
Dustin
  #4 (permalink)
Old 07-24-2003, 09:40 AM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a good reputation on FTE. 46fordtruck has a good reputation on FTE.
door lock cylinder
I'm not sure what kind of set screw is used either, but I know no screwdriver, or allen wrench would gat a hold of it well enough. I ended up using an easy out to just get it out. I haven't yet reinstalled a new lock cylinder, so I'm not sure how to get it securded back in the door again.
__________________
Gary-
'46 Ford 1/2 ton
  #5 (permalink)
Old 07-24-2003, 09:59 PM
door lock cylinder
an easy out?
__________________
Dustin
  #6 (permalink)
Old 07-25-2003, 09:53 AM
door lock cylinder
Yeah, those things you use when you break the head of a bolt, drill a hole in the broken stud, and then use a special bit to extract the broken bolt. Any hardward store has them, and most auto parts stores carry them.
__________________
Gary-
'46 Ford 1/2 ton
  #7 (permalink)
Old 07-25-2003, 11:43 AM
door lock cylinder
ok. thanks.. ill check that out
__________________
Dustin
  #8 (permalink)
Old 01-26-2005, 08:32 AM
Elder Rodder's Avatar
Elder Rodder Elder Rodder is offline
Elder Rodder is starting off with a positive reputation.
There is an Allen head screw, about 1/8 inch socket, that is accessed from the edge of the right door through a small hole in the edge as you open it. This screw bears on a recess in the lock assembly and keeps it in the door and against the panel where the stainless flange of the lock meets the outside skin. Back this off, it may require some heat to free-up the screw, and then back it out. If the socket is stripped then use an easy-out. If you clear the lock assembly, or at least take the tension off of it, it should slide out of the door. Getting the assembly back into the door is a little tricky when aligning the square connector rod back into the square opening of the mechanism that opens the latch. Bob Drake has replacement lock assembly with keys if the old one is in bad repair or you don't have the original key. Instructions for reinstallation come with the new BD assembly and show a cute trick to line-up the square connector with the square hole in the door opening mechanism.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
