Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
76 F600 7.3 Powerstroke Conversion?
Old 03-02-2015, 11:07 PM
martyanderson10's Avatar
martyanderson10
martyanderson10 is offline
I know that putting a 7.3 in a light duty dentside is a huge undertaking to get it to fit. My question is would a 7.3 physically fit into a F600 any easier? On the lighter trucks a big issue is having to relocate the crossmember and fabricate a new one. Is this also true on a large truck?
Old 03-03-2015, 06:03 AM
allis327's Avatar
allis327
allis327 is offline
As far I know you need to use the 7.3 gauge cluster since the 7.3 is a highly computer controlled. I looked around and asked on a couple of forums and found no conversion kit for the electronics. Most people go with the Dodge/Cummings swap.
Old 03-03-2015, 08:11 AM
martyanderson10
Yeah I know that a Cummins is a much easier swap in the light trucks. I love my 7.3 CC F 350. I have an opportunity to buy a complete running 7.3L donor vehicle pretty cheap.
Old 03-03-2015, 07:19 PM
allis327's Avatar
allis327
allis327 is offline
I was in the same boat best deal ever I just could not make it work.
Old 03-08-2015, 10:28 AM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
Conversion is fairly straightforward using a front motor mount from a 6.9/7.3 navstar motor... mounts to the crossmember single mount in front . Early versions didn't need any special dashpod... not sure where you got that
Electronic versions t444e do need all electronics to run...
While the 7.3 is a great motor the 5.9 has been used by ford as well... and would probably be a better upgrade ... used 7.3 s require careful inspection to get a good one and 5.9 s in my opinion are more worthwhile to rebuild and last longer in medium duty applications ... 7.3 buses with 250k are at service lifespan... 1/2 of the Cummins... you'll spend the same..get the better motor for your application
Both have been used for swaps... a quick search
should bring up some threads
Plenty of room for either
Old 03-08-2015, 05:05 PM
allis327's Avatar
allis327
allis327 is offline
I was just going from info from the 99-03 7.3 forum and my exp trying to find a way for the electronics to work for those model years. I agree Cummins would be the best.
Old 03-10-2015, 10:28 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
Or you could put a 7.3 IDI in it. Early 90's Ford trucks.
Old 03-16-2015, 11:46 AM
Notmeofficer
Agree .. way easier conversion.. and you might even find the whole shebang out of a bus.. even better a ford bus..
Old 03-16-2015, 06:54 PM
martyanderson10
I have to disagree about the Cummins being a better engine than the 7.3 PS turbo. I can tell you several examples from very close knowledge that have went 500K with NO major maintenance. I even know of one that went 740K in an Econoline E350. It is the best diesel Ford has ever put in a light duty truck. I know that the earlier 7.3 don't require al the electronics BUT they have no turbo and don't have near the power.
I have owned two later 7.3 Powerstroke turbo's and I love them.
Old 03-17-2015, 08:53 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
Old 03-18-2015, 05:21 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is online now
How about a 429 industrial gas? That will bolt in and haul ***.
I like the idea of the 7.3 turbo in there however. That would be sweet. A 5.9 would be a dog. Since none of the cross-members are welded on the f600, you can grind off some rivets and change some things around if you had to. The f600 engine cross-member is under the front of the engine timing cover. There is exactly 3" more under hood clearance on an f600 than a light truck, and have the same front-to-back space.
My 1960 ford with the 429/5speed/double frame/two speed rear will Blow the doors off any 5.9 powered rig the same weight.
Old 03-18-2015, 10:30 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
That superbronco is cool!
Old 03-19-2015, 11:52 PM
68Mercury250Ranger's Avatar
68Mercury250Ranger
68Mercury250Ranger is offline
this was what attracted attention
F450 chassis with a dana 60 front axle
7.3 powerstroke should be a nice fit, just need a Navistar donor truck for the chassis parts, and while you are at it................some came with a 7 speed spicer.
have a good friend who has a 1979 F350 cab/front clip on a 1997 F450 rolloff chassis . 7.3 powerstroke Zf5spd. he hauled my Centurion to my new place this summer, man it got a lot of looks and thumbs up.
Old 03-20-2015, 09:51 AM
SDElwood's Avatar
SDElwood
SDElwood is offline
Originally Posted by 68Mercury250Ranger
I have a good friend who has a 1979 F350 cab/front clip on a 1997 F450 rolloff chassis . 7.3 powerstroke Zf5spd. he hauled my Centurion to my new place this summer, man it got a lot of looks and thumbs up.
Pics or it didn't happen!!!!
Old 03-20-2015, 01:15 PM
68Mercury250Ranger
my sincere appologies
Quick Reply: 76 F600 7.3 Powerstroke Conversion?
