05 f150 5.4L 2WD 90K mi Changed plugs and COPs missing worse
Old 03-02-2015, 08:48 PM
Les99's Avatar
Les99
Les99 is offline
I have a 2005 F-150 5.4L 2WD 90K miles. I started getting a misfire and hard jerk when going uphill. No codes for a few days but misfire got a little worse and more jerking at full throttle acceleration or level throttle up a hill got codes p0300 and p0171. I replaced the fuel filter cleaned MAF and changed plugs Motorcraft plugs (none of them broke during replacment). Miss got worse. Missing at idle and no power 3K rmp to get to 40. Only code pulled was p0171. Replaced upstream O2 sensors and COPs. Will barely idle now. Dies when put in gear. Full throttle barely moves forward a few feet just sputters. Checked vacuum lines can’t find anything. Only code I get is P0171. Fuel injectors next? Or shop?
Old 03-02-2015, 09:51 PM
air1jpg's Avatar
air1jpg
air1jpg is offline
Check your cat. converters??
Old 03-02-2015, 10:06 PM
Les99's Avatar
Les99
Les99 is offline
I loosened right side flange (bank 1) upstream of that CAT. It was loose enough to be able to see the 2 pieces of the pipe move away from each other and it had no change on the miss/no power. Did get really loud when I started it up so I think it should have relived any back pressure.
Old 03-05-2015, 08:58 AM
F150Torqued's Avatar
F150Torqued
F150Torqued is offline
I would try a battery-re-learn next
@Less99
In this situation it would be useful to have some OBD2 readings from a scanner tool. But short of that, it appears you have done all the right things.
The only other suggestion I have is (assuming you haven't already done it - as you didn't mention it) is to reset the PCM and do complete re-learn procedure. It is a common mistake to replace a weak or faulty sensor (which has been producing bad input signals to the PCM for thousands of miles), and then expect the engine to run perfectly on the PCM's severely adjusted values it has developed trying to compensate for the bad sensor or input. Review the thread at:
Battery relearn process - Ford F150 Forum - Community of Ford Truck Fans
The PCM has stored fuel "Trim" values for different rpm ranges, load conditions. After replacing O2's or other sensors, the PCM doesn't know that. It is then relegated to using 'BUM' values for injector pulse width and throttle position or cam timing, or may be trying to OVERCOMPENSATE the other direction from those BUM values. Some PCM's even have a "driver satisfaction" routine that tries to logically adjust parameters to satisfy the type driving YOU do. ALL that is out of whack after a major tune up.
I would disconnect the battery for a long period of time (even overnight) to make double dog sure the intermediate storage in the PCM is completely cleared, then go through the re-learn process.
After doing this on my truck (following an intake manifold replace) it took maybe ten driving cycles for it to settle down and clear up.
Good luck
harveje
2004 - 2008 F150
152
04-23-2019 07:13 AM
mark_5102
2004 - 2008 F150
03-24-2017 10:09 AM
Fordmom530
Modular V8 (4.6L, 5.4L)
03-22-2015 08:30 PM
jimjoebob99
1999 to 2016 Super Duty
11-14-2011 07:30 AM
2000 F-150
1997 - 2003 F150
02-11-2005 12:34 PM
Quick Reply: 05 f150 5.4L 2WD 90K mi Changed plugs and COPs missing worse
