5.0 engine to c4 transmission
Old 03-02-2015, 07:10 PM
Color sarge's Avatar
Color sarge
Color sarge is offline
Unhappy 5.0 engine to c4 transmission
I have a 1952 F1 with a 351w and c4 transmission. I also have a 1986 5.0 roller motor that I would like to install. What problems would I run into? I am aware of the balance issue, but, have heard the c4 could have one of 9 different bellhousings. Yikes! Thanks
Old 03-02-2015, 07:25 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,423 Likes on 1,379 Posts
I don't think you'll have a problem. Most of the different bellhousings are on the earlier models, 5 bolt, 6 bolt, different flywheel teeth count, etc. If it's from the 351, it should have the larger 164 tooth bell, which is what the late models ran. Use the same block plate and starter as you're using now, get the correct balance flexplate for the 5.0 (making sure the tooth count is the same) and you should be in business.
Old 03-02-2015, 07:29 PM
Color sarge
Thanks. Didn't think it would be that easy.
Old 03-02-2015, 08:16 PM
c91x's Avatar
c91x
c91x is offline
Most c4's have a 157 tooth flywheel. I would bet that's what's behind your 351. You'll probably need a 157t 50oz flywheel to run behind the 302 but you won't know till you split the two and measure the flywheel
Old 03-03-2015, 08:54 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Almost all the SF engines (older 289s thru 351C) have the same bellhousing bolt pattern including straight 6s. Balance of your flexplate & number of teeth will be your issues. I'd try to keep the Flexplate from the 5.0 if it's still available. Might wanna get the 5.0s starter as well.
This site might help: Ford Flywheels and Flexplates
mh822
84
07-11-2023 09:00 PM
RustyBarnard
08-11-2016 08:47 PM
juchertf100
09-25-2008 03:34 PM
Brian460
06-26-2003 05:23 AM
rosentr
02-21-2003 10:35 AM
Quick Reply: 5.0 engine to c4 transmission
