The 59 AB in the attic
Looks like the K designation is for a .010 oversized rod bearing. A few things are not coming together with my plan...... Smart thing is turn the crank while it's sitting right here in front of my face. Not as much fun as a shoelace, but it just might be the right thing to do at this juncture. Guy on the mainland Dave Tatoms custom engines has 59 ab cranks turned on an exchange basis for 225.00.......
I have a set of 8ba rods, but already ordered the .010 floaters. Bob Selzam gets 125.00 for a set of ford nos floater rod bearings and 95.00 for mains. I see the rods often go for 200.00. After I was satisfied with the shoelace polish job as far as pits, scoring etc I had 2 journals that were a bit small for the .002 bearings and one main that was still too big for the .002 mains. I see some places where they sell them individually, but still they aren't totally round, and since the rest of this particular engine is a fresh rebuild I keep thinking it might be false economy to put a hand job crankshaft in an otherwise freshly machined engine, when a ground crank is available locally for 225.00. I have the 59ab that came out of last winter's '47 2 ton and the one that's coming out of this panel truck to hillbilly with for the next project. Last winter's had been through a flood, but I got it unstuck once out of the vehicle, and this years hasn't budged yet with everything I can throw at it. I can handle a really rough exterior but deep inside I want it to not only purr like a kitten, but be reliable for trips as well.
Got my new rod bearings today and I took a std crankshaft to Tatom's shop for a 10/10 regrind. I know it would have run well if I had just thrown in the new bearings, but just couldn't bear the possible remorse of not doing the right thing when the engine is on the stand and the crank is just a lift-out away from being right. While the crank is on the mainland I'm thinking about valves. I now have about 20 good intakes and only 3 good exhaust valves. I have about 20 or so guides that seem to fit well. Just need some more exhaust valves. I am using the one piece guides and the 8ba valves. Nobody on the island grinds them. The seats are as new in the block.
#29
krustiy lusti
01-23-2016 05:31 PM
jbancroft
11-30-2014 05:29 PM
46yblock
02-16-2012 06:03 PM
polarisman729
05-31-2008 02:15 PM
