Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Best oil and fuel filters, both quality and cost
Old 03-01-2015, 11:15 PM
Poppa Squirrel Poppa Squirrel is offline
Poppa Squirrel is starting off with a positive reputation.
Looks like I will be buying tools that are new to me to keep my truck healthy.
Now I need to get set up with good oil and fuel filters.
Which are the best overall?
Which are the best value, even if only from a particular source?
Old 03-01-2015, 11:17 PM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is starting off with a positive reputation.
There is extended oil filters that alot of people run. I like using the fomoco filters for oil and fuel
Old 03-01-2015, 11:45 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I run Schaeffers 7000 oil and their trans oil.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old Yesterday, 12:54 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Just use motorcraft filters. Really can't go wrong there.
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo w/wicked wheel, 6637, elec. fuel,rosewood stage ones,php hydra,arp studs, comp springs, smith brothers push rods, honeybadgerjr hpop,riffraff res,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
Old Yesterday, 03:05 PM
dclack's Avatar
dclack dclack is offline
dclack is gaining momentum as a positive member of FTE.
Most will agree that the Donaldson DBL7405 is the best filter, but everybody will have a different opinion on oil. I just buy the Delo400 at Costco whenever it goes on sale. The DB7405 is larger than a stock filter and does hang below the oil pan about 1-2". If you you don't like that, then just get the Motorcraft filter.
__________________
'97 F250, 7.3L PSD, ZF 5spd, CC, SB, 4" AFE Intake, 3" dp, 4" Straight Pipe, 6" Lift, 3.73 Gears, D60 Swap with ARB, 10.25ls Rear, Glowshift Gauges and PHP Tunes! Wish List: Rosewood Stage 1s, Terminator T500 HPOP, IC
'73 Bronco, 302 HO EFI, ZF 5spd, D20, D44 Front, 9" Rear, Detroits Front and Rear
'03 Expedition, Eddie Bauer, 5.4L, Wife's Car = No Upgrades Allowed
Old Yesterday, 03:24 PM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
Quote:
Donaldson is the one I use.
Just thought I would add these pics, it is large but an excellent filter.
Click the image to open in full size.
__________________
Rich-97 F350 SC Dually long bed 2wd, 5 speed, 410's, 145000 : 6637 intake filter, Tymar 3" down pipe, cat delete, IDM 140v, Digital pyro gauge, Rosewood Stage 1's, FPR shim, CCV mod. Valair 400 HP Organic Clutch, GPR manual momentary switch, Superchip 1700 tuner/programer.
To do would be install 6.0 intercooler (need pipes and boots)
Old Yesterday, 03:51 PM
nossliw's Avatar
nossliw nossliw is offline
nossliw is gaining momentum as a positive member of FTE.
+1 Here Donalson 7405 (Elf7405), Rotella T6 5-40 every 4000 miles. T6 is shipped to your door for 19.57 a gallon off amazon. Can't go wrong there.
__________________
96 F250 CCSB One nasty 12V Fummins 3:55's, Wife's future baby wagon
97 SCLB 7.3 PSD ZF5, 4:10'S, DP tuner, 6637, 4" Bellows, T4 w s366, Efuel, 3" plenums w/ 6.0 IC/Rosewood Stage 1/waterinjection /T500
Old Yesterday, 07:52 PM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
I run the Donaldson as well; fyi the last one I purchased was blue. Seems they modded their product line. As far as lube oil goes I run Rotella conventional.
__________________
96 f350 CC PSD SRW Roll-a-Long 4" lift, 5" Diamond Eye SS strait through, Ts5 w Jody's tunes, 203 stat, KT LED tune indicator, banks gauges, 6637, boost fooler, 35s, Weld Super Singles, 4.10ls, zf5spd-w-SMF and LuK... Fed PCM-W-Splits, see quote below.....
92 Ducati 907ie,
Rare does not always mean desirable, it's rare that I s$!t my pants but it's definitely not desirable...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
