Ford part # for tensioner pulley
Old 03-01-2015, 05:05 PM
queen of spades's Avatar
queen of spades
queen of spades is offline
Anyone have the correct part number for the tensioner pulley on a 2002 F250 with 7.3 diesel (single alternator if it matters).
Replacing my serp belt soon and thought I should replace this too.
Old 03-01-2015, 05:18 PM
sowaxeman's Avatar
sowaxeman
sowaxeman is offline
Readily available at Autozone for ~$25...either smooth or grooved depending on what you need. I used a Duralast on my 94.5 PSD when it broke....lasted ~4 yrs and was still fine when I sold it. I'd put one on my '02 if I needed one.
....and I just realized you said TENSIONER, not Idler ;-) Idler is what I was referring to, my bad ;-) But for what its worth they show the Tensioner Pully for ~$65.
Old 03-01-2015, 10:27 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
a lot of us use parts from some of FTE's sponsor's
Serpentine Belt Tensioner 99-03 - Riffraff Diesel Performance
Old 03-01-2015, 10:30 PM
queen of spades
says 404 not found
Old 03-01-2015, 11:14 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Originally Posted by queen of spades
says 404 not found
The link worked when I tried it, but try this one if you need. If not the are under the OEM section.
Old 03-02-2015, 07:27 AM
queen of spades
Thanks for the link... good price.
Old 03-02-2015, 07:30 AM
bigb56's Avatar
bigb56
bigb56 is offline
So does the spring wear out or just the bearings? I pressed new bearings into mine a couple years ago as a preventative measure and everything seems to be fine.
Old 03-02-2015, 07:33 AM
queen of spades
Some of the youtube videos show that the unit "separates" somehow. I wanted to get a new one in there along with the serp belt so I'd have a baseline going forward.
queen of spades
Just pressing in new bearings is cheaper, and if I know how to check if my tensioner isn't separating I'll do just that.
amdriven2liv
06-18-2017 10:01 AM
93RangerXL4x2
03-06-2011 07:26 PM
SturgeonHunter
07-09-2010 07:12 PM
wtroger
08-31-2004 08:53 AM
blingbling
02-06-2004 11:26 PM
Quick Reply: Ford part # for tensioner pulley
