1951 F1 New Project
1951 F1 New Project
So I have been a '48 through '52 F1 fan for a long time and finally had a 1951 1/2 ton follow me home. Last registered in 1979 it has the usual issues from sitting for 35+ years but appears to have had a relatively easy life. All the trim is with the truck and although the bed is missing the wood it is not beat up like most trucks that had a working life. It will likely end up as a parts truck as I can find no identifying marks on the truck that would provide a serial number or similar.
There are no firewall or glovebox plates on the truck. Where the serial number would have been stamped on the frame rail is so rusted as to not yield anywhere close to a full number. Also no stampings on the firewall apart from the those in the photo below on the DS. Any idea what these might be related to? I can find no marks on the rear of the frame rails but have not looked on the frame under the cab yet. Anyways this will get me started on my journey of owning a nice F1 truck. Lots to learn. Looking forward to being an active member of the forum.
Welcome to the forum, and thanks for a picture! Good to see another stylish 51-52 joining up.
The serial number will be on a plate on the glovebox door Ratings Plate, but the one that counts is stamped onto the top of the frame rail, about where the motor mount is. Wire brush or scotchbrite carefully to avoid removing any detail from the stamping. It should be F1R1xxYYYYY. Ford used the "I" instead of "1" on many of these.
Welcome to the forum. That is a solid looking truck. Have you looked on the top of the curb side frame rail between the cab mount and the radiator support area for ID number stampings? They are hard to view sometimes. Depending on what state you're in a title may or may not be obtainable. I wish you luck with the title issue.
I have de-greased and lightly wire brushed the frame rail area. This is not the best photo but you can barely make out a couple characters of the serial number if you shine a flashlight at a shallow angle across it. No way to get a full number from that area. I have very little knowledge of the way a no serial number vehicle would be handled in NC, any experience there would be appreciated.
This is a hobby and a longer term project for me so I don't mind looking for another partial / unfinished project / rusted truck that does have paperwork or at least numbers that I can transfer my donor parts to.
I have an English wheel and basic sheet metal shaping equipment as well as a TIG welder so I will be spending many hours repairing the sheet metal. That should keep me busy for quite a while. I'll post that stuff up on here as it happens so those of you with expertise in that area can help me out. I am definitely a semi-novice in that area even though I have built a few cars some from the ground up.
serial number location
Walt I need to remove the front sheet metal (and cab) to give the front of the frame a better inspection but I can't see any legible markings so far. Also I want to check under the cab but I think as this truck doesn't have any firewall serial number stamping that it's one of those trucks that won't have a frame stamping under the cab either. Hey I'm happy even without a serial number as the truck is worth a lot more more in parts than what I paid for it.
So, not to sound sketchy......
If you have a truck that you paid for and a title stating that you own that truck, but your truck has an illegible VIN stamping, can you repair/restore that VIN area by "freshening up" the stampings?
I dont see how they can force you to scrap the truck, what If you went with a different chassis (something like a TCI or restomod) How do you have a VIN marking (other than what would normally be on the firewall)?
ALBUQ F1 - If I could find someone who understood the process of getting a state assigned VIN I would explore that option. I know by going through my Cobra registration that because these things are few and far between in the daily DMV process that you have to be lucky to reach a knowledgeable individual.
Once you get good access to the area where the VIN should be located, spend the time to carefully clean the area well. You can buy an acid that will bring the numbers up. Cops use it on guns where serial # has been ground off and guys use it on engine blocks if decking the block has ground off the VIN#. Check with Eastwood or Summit, I know I have seen for sale.
Having the original correct VIN # is ALWAYS the best plan to get ownership of classic vehicle, and down-the-road it will increase the value of your truck.
