84 f150 engine missing at low rpm
#31
hey
the vacuum is hooked up correctly to ported vacuum.
I would replace that hose too.
the meter to use is a multimeter 20.00 for a cheap one set it to ohms its an upside down " u ".
pull the connector from the distributor and put the leads on the purple and orange wires.not the black one.
(I already put the specs in my previous post)
personally I would just get a rebuilt distributor advance has the for like 40.00.
a module is s little less that the whole thing plus you get a new vacuum advance unit.
#32
I'm leaning more towards the ignition. It studders hot and cold. Just at a lower rpm the More gas you give it it goes away. Where should I start timing? Looks like the truck has new dst cap and rotor. New plugs and wires. If my vacume advance was bad on the distributor would it cause this. I know the carb is pulling vacume on it. Because I tested it
#33
Road rash just saw your post thanks for the details that's what I needed. The truck started right up this morning with no starting fluid I retarted the timing a little just by ear and seems to be running better. I will know more the next time I put it on the interstate. I just replaced my exhaust manifold and now it's leaking in between intake and exhaust where they connect. I think it's the new exhaust manifold because one of the bolts won't tighen just keeps spinning. The bolt is NOT broken off. I think the manifold cracked around the threads. Any way thank everyone for your help.
#36
Dr. Johnny Fever
09-29-2015 07:22 AM
jamesB3
21
04-01-2015 06:54 PM
ip8425
07-07-2012 02:13 PM
shark13
08-23-2009 11:05 PM
downhillpat
10-23-2004 10:24 PM
