Dual Function Reservoir Replacement
Old 02-27-2015, 10:10 PM
The Gypsy's Avatar
The Gypsy
The Gypsy is offline
Good Evening,
This is my first post, but I have been lurking the boards for quite a while. I have a 1989 F350 2wd with a 5.8l 351w. I have had all the issues with the dual tank system that everyone else is having. I have replaced both in tank fuel pumps and replaced the rear tank. The rear tank had 10-15 year old gas in it that had turned into "crude oil". My tanks were cross filling, now I switch the lines on the Dual Function Reservoir (DFS) every once in a while in order to avoid over flow. Sad but true.....
The issue... I purchased a new DFS. Popped it in, in all of about 10 minutes. I jumped in the truck hoping too cruise around switching tanks for the fun of it... Worked great!!! Until I looked under the truck and it was leaking fuel from the connectors at the DFS. It appears the "quick connectors" are not snug on the new DFS. Did the old ones expand? D I have the wrong DFS? I ordered a 1989 and the part numbers match up.
Any Thoughts??
Old 02-27-2015, 11:34 PM
wtroger's Avatar
wtroger
wtroger is offline
Check and make sure te o-rings are in the connectors. I have seen them come out
Old 02-28-2015, 10:40 PM
The Gypsy's Avatar
The Gypsy
I think I have the wrong DFS. I have Part #F1UA 9b263 AA. I believe I need F1uz 9b263 b. Shake my head....
rougeriver
07-27-2017 08:05 PM
iwals
02-19-2016 08:27 PM
superrman77
1999 to 2016 Super Duty
18
10-22-2010 11:37 AM
mark460
01-15-2008 12:26 PM
Raymond Bourque
10-15-2006 08:47 PM
Quick Reply: Dual Function Reservoir Replacement
