Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1966 Ford F100 VIN help
Old Yesterday, 08:31 PM
Death_Eagle_571 Death_Eagle_571 is offline
Death_Eagle_571 is starting off with a positive reputation.
Exclamation 1966 Ford F100 VIN help
Hey guys, I'm new here and I just picked up a really nice F100, and I was wondering mainly which straight-6 engine it has, the VIN starts out F10A which leads me to believe its the 240ci not the 300ci but it looks pretty big, so I'm not entirely sure, it does have the Custom cab from what I can gather (the separate oil/temp/fuel/amp gauges) if that makes any difference, Is there any5thing I can look for on the engine itself to identify it?
Old Yesterday, 08:48 PM
banjopicker66 banjopicker66 is offline
banjopicker66 has a good reputation on FTE.banjopicker66 has a good reputation on FTE.banjopicker66 has a good reputation on FTE.
Welcome to FTE.
The best way to tell the difference between a 240 and a 300 is to measure the stroke.
Remove any spark plug, and insert a 12" piece of white electrical wire.
Rotate the engine until the wire is at its lower point.
Mark the wire at some point, such as the valve cover lip.
Rotate the crankshaft until the wire is at its highest point, and mark the wire at the same witness spot.
Measure the distance between the 2 wires.
For the 240, 3.18" is the stroke, and 3.98" is the stroke of the 300.
Suggest two things:
1. Compare the VIN on the title, on the door Warranty Plate, and on the frame to make sure they all match. The frame VIN is stamped on the upper passenger rail, about where the front of the engine is. It is faint, and may require some wire brushing. Do not use a grinder, just a wire brush.
2. Post the entire Warranty Plate information and we can decode it all for you.
Again, Welcome to FTE.
__________________
John - Banjo -
Old Yesterday, 09:04 PM
Ok, will do, thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
