Should I grind and finish these welds or leave them be???
Ok so I am pretty much finished welding these. I can grind them down, but I also don't think the welds look bad. They will look even better after blasting removes the final boogers..........
What do you think? Grind and finish? or leave them?
Keep in mind that no filler can be applied do the temps, and powder coating process.
I tend to agree, it just feels "unfinished".
The outer edges will not be an issue to dress and metal finish.
How about the fillets around the bungs and flanges? What is the best way to get them finished down?
I use a carbide bur, and a sanding drum. With this approach I still tend to "gouge" some places and leave rough marks. It is not typically an issue though because a good primer or a little filler will hide them. But in this case I cannot use it.
So, what's your recommendations on tooling?
You have put alot of work into that project and should be commended for it. IMHO I would do the additional time of finishing the welds. Make the curves look like they flow and the edges roll. 8pc Dual-Cut Carbide Burr Set - 1/4inch Shank
Cylinder Porting and Finishing Kit
1/4"" 90 Angle Die Grinder 1/4"" Medium Die Grinder
Go slowly with light pressure and you will have a nice looking finished pc ready for the finish
