Which tranny would be best?
Could be handy to know if faced with a few unmounted (or mismatched) carbs missing their ID tags.
See here:
https://www.ford-trucks.com/forums/1...th-an-aod.html
C4, C6 kickdown rod linkage (the lever to the right of and behind the throttle lever pointing up):
AOD TV rod linkage (the lever to the right of and behind the throttle lever pointing down):
Originally Posted by Cienega32
Are there any obvious visual differences between the two kickdown linkages that someone can make note of (in the case of missing ID tags)?
operator exmark
12-04-2007 07:38 PM
MetallicaFan39
10-15-2003 06:25 PM
