Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
help please got over heating problems after water pump replacement!
Old 02-26-2015, 06:16 PM
willydub willydub is offline
willydub is starting off with a positive reputation.
hey guys im a new member here but have been reading this forum for a good long while always great help here! im kind of in a pickle and could use some help! about two weeks ago i purchased a nice little 2001 4.2 v6 standard tranmission 2wd truck for a fair price. needed a couple of minor issues fixed which i took care of the first couple days. after a bout a week and a half of driving i started to notice my temperature guage rising. i noticed that i had no flow in the cooling system so i tore it down and found that the impeller on the water pump had sheared off and was just sitting there. so i installed a new water pump and buttoned her back up thinking that this would be the end of my overheating problems... nope! while i had the radiator off and the water pump off i flushed thru the system with a water hose and thru the radiator from both ways and thru both heater hoses both ways. after filling the system up 50/50 with water and antifreeze and making sure i was at the right level i took it for a test run. i drove about six miles and saw the temp start to climb. i pulled over and let the pressure off of the de-gas bottle not recommended but i chanced it rather than fry my motor. as soon as i let off pressure it went right back down to cool and i started off again. i drove about 25 miles all together abd had to stop and repeat this process about three of four times. i just figured it was working trapped air out of the system. the problem is four days later its still doing the same thing always after about ten minutes of running(my commute time). am i missing something or does anyone know what would cause this? please help i cant go anywhere without pulling over every 10 miinutes... any input would be greatly appreciated!!! frustrated as all hades!! also my heater which didnt work previously now is coming and going... also replaced the thermostat and fan clutch...
Old 02-26-2015, 06:42 PM
nlassley nlassley is offline
nlassley is starting off with a positive reputation.
Did you replace the thermostat?
__________________
Speed is just a question of money, how fast do you wanna go.
98 ranger 2.5, 5 speed 19 lb injectors and a thrush muffler.
Old 02-26-2015, 07:07 PM
yes as well as the fan clutch which was a little wobbly.
Old 02-26-2015, 07:10 PM
also checked belt routing, fan rotation blew thru all inlets and outlets with the hose when i flushed it.
Similar Threads
95 5.8 cooling system questions ZombieSlayer 1978 - 1996 Big Bronco 11 03-20-2015 01:33 PM
please help! over heating after water pump replacement!!! willydub 1997 - 2003 F150 6 02-27-2015 09:00 PM
Coolant weeping thru all rubber hoses FEmtnmax Cooling, Heating, Ventilation & A/C 7 01-04-2006 08:15 PM
78 F-150 thermostat problems fordmando Cooling, Heating, Ventilation & A/C 10 03-21-2004 12:13 AM
head gasket?- long M Tucek Aerostar 12 10-09-2003 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
