slight rpm flutter at idle
My 08 does it too. The FRP is fluctuating when it's doing this. Don't know if its the pressure sensor, or the pump. It only happens on occasion. I have an Edge Insight CTS and set one of the gauges to read the Fuel Rail Pressure. At idle, and not acting up, it sits at 5.1k, but when idling rough will jump from 4.9k to 6.1k.
Are you guys talking about almost a slight loping?
Mine does that because I have the VVT turbo controller disconnected.
If I plug it in, it idles perfect.
Unplug it, it kinda lopes or slightly surges when idling, mostly when cold.
I'm just saying this because obviously sensor inputs are capable of causing this condition.
SoCar72
09-18-2016 11:13 AM
JayzDaddy
07-01-2013 10:14 PM
Jaaaaaaackman
05-31-2006 07:47 AM
