New to the Diesel world
Hey names dan and i just recently purchase a 1987 F350 6.9 IDI.
I am currently having a few issues with the truck and i am having no luck
with finding the correct information. My truck takes a while to start i have to keep cranking on it and after a while of trying it it will turn over. New battery and had the charging system checked as well as the second battery. And lastly i cant seem to find the wiring schematic for the tail end of the truck i have no reverse lights. Any help would be greatly appericiated.
on
The reverse light switch is on the drivers side of the transmission towards the front and up high. Its pretty hard to see. It has a two wire connector. You should have power to one wire with the key on. If so you can jump the two terminals and see if the lights come on. If so the switch is bad.
What have your temps been? If you plug it in does it fire right off? Air intrusion will usually allow the truck to start like normal and then stall. Then it takes a lot of cranking to start agian. If it just wont start I would think it was something else. What is the mileage on the IP and injectors? Does your high idle work when the motors cold?
Disconnect the second battery (the old one) and measure its voltage with a good multimeter. Not a dummy light. You need tens of volts, like 12.1V or 11.7V. You could have a bad cell in the old battery that is draining the efficacy of your new battery.
How old is your Voltage Regulator? Starter? Glow plugs? What kind of GP's?
Also, how clogged up is your Fuel filter?
Use a meter to check the block heater. There should be continuity between the 2 sides of the heater cord. If it checks out, plug it in overnight (or for a few hours) and then see if it fires off. If it does then 9 times out of 10 it is the GP system probably some are burned out. Its a pretty easy fix.
With the miles in it, it could be a worn IP and injectors. When I got mine it had a hard cold start issue. New GPs helped, but it didnt completely go away until I replaced the IP and injectors. I would at least suggest timing the pump.
I pulled out a GP kept it connected and turn the truck over to see the wait to start light went out and check the GP it was cold not one bit warm to the touch. When the truck is plugged in it warms up fine and turns over. There is no leak or holes in any fuel line i check from the mechanical pump to the fuel rails and all the lines in the engine compartment. All check out fine, i traced the line to the tanks and its all good as well. About the GP i checked the fuse under the driver seat it was good and just to mark it off as a possibility i changed it to a new one still same thing happened. I do have extra filters that i should just changed anyway. The conditions of the glow plug when i pulled it out was black.
About the block heater could that be the reason why the GP arent working?
