Factory or aftermarket sliding rear window?
I need to re seal my rear window and looking at LMC for a new gasket there is a different gasket for a factory slider over a standard window. so the question goes, what do I have and how can you tell the difference? what gasket do the aftermarket sliders use if that is what I have?
here are a couple pics, 1 showing the latch on the inside and the other showing the outside.
It's a single latch on the inside with two sliding sections, where the LMC pic shows a single sliding section in the middle but that is just the pic for selling the gasket.
What do I have and what gasket does it need?
Thanks
Brian
Thanks
Brian
That is the factory slider. I see that you have the separate trim in the middle of the seal from the rear view. I am not sure if LMC has that exact replacement. The one they have will not have that extra trim piece, but should work. Sometimes you can get the correct gasket from your local glass shop. Bring the truck with you.
Bill - Someone told me that a later slider, with a better lock, could be used in our trucks. Any truth to that?
Factory slider has a glass channel that is very wide to fit the tracks.
Aftermarket slider windows are manufactured with a flange that simulates single glass thickness, and uses the standard gasket.
If you have chrome locking trim, you must use chrome locking trim!
I tried, and failed using a regular gasket.
Gary,
Yes, C.R. Laurence sells an all metal slider latch that fits and works much better.
DVL2, DVL2 - CRL Replacement Metal Backslider Latch
I swapped mine over a decade ago.
Gary,
I leave it open for my dog to guard the tools while I'm in the store.
Seems there's a bunch of thieves in the parking lot of any 'big box'
One will park alongside with a van (blocking the view) while another will tail you inside, giving notice by text if you are coming back out.
She's kind, but nobody likes a pit bull when there's another target one isle over.
