87 ford ranger 2.9. wont start. ignition firing while key on engine off
I've got an 87 ford ranger 4x4. The truck won't start. The ignition is firing off with the key on engine off. Have been trying to figure this out for a while and I'm out of ideas. When I got the truck the transfer case was blown. The people I got the truck from drove it to here it sat. I check the wiring but the transfer case to make sure it diet get damaged causing a sort. When I got the pcm was missing. Took one out of a bronco 2 and changed the relays on the fender.
Here what I've done so far
Relays
Pcm
Complete tune up.
Distributor and ignition module
Replaced and repair some grounds.
Relays
Pcm
Complete tune up.
