Air Helper Suspension kits
Hey there gameboynws and welcome! The core inside the nipple may be loose. If you don't have an onboard compressor set-up and have to fill the bags manually, then it might be the cause. Get some soap and water in a spray bottle to see if you can locate where the leak(s) are. Unless they are damaged during installation or you are doing some jumping with your rig, the springs may punture the bag. If you do have the on-board compressor, use the soap and water to check for leaks while you run the compressor. You may have a bad line or fitting. Good luck and get back to us.... Talk with you later....
