97 powerstroke SCLB freshen up and zf swap
Bought this truck a month and a half ago.
Was too good of a deal to me for me to pass up, Plus i kinda liked it
bought it as a beater truck. all my trucks have been to nice and i worry alot. I absolutely love having a beater truck now!
1997 f250 4x4 sclb
7.3 e4od canadian built truck
220k miles 3.55 gears
When I bought it,
has 4 inch lift on 35s
Neweer injectors, runs like a top.
e4od isnt factory one, has been replaced somewhere down the line. already sold it for 500
Wheels and tires came with receipts, warranty, only had 400 miles on them. 315/75/r16s
Came with a FULL zf5 speed swap with a fresh zf5 less than 5k miles on it out of a f-superduty.
A LUK SMF
Manual PCM, adapter plate, bell housing bolts, pedals, full cluster, full column(neither of these I needed, just the PRNDL blank cover) Crossmember, t case linkage, clutch and slave cylinder.Shifter, shifter boot, literally everything but a rear driveshaft.
came with a used clutch but i will be putting a valair in it.
Truck needs some odds and ends. alot of parts i have sitting around already,
front tank leaks, but i have one for it from a cc psd i parted out.
install pass side step, its sitting in the bed with the piece of angle to reinforce it.
am putting the bigger mirrors on it, The "gooseneck" ones.
drivers side door hinges and striker
Probably glow plugs, havent diagnosed.
I plan on continuing to drive this through winter, to keep my green 97 off the road, I built that in 2013.
gonna buff and wax it. Was tu tone with light blue on bottom. PO didnt like it. bed-liner is only hiding rust on drivers side fender, everything else is solid and wasn't bubbling, i know this because it was a friend of mine that bought it and bed lined the bottom, so i saw it when it was tu tone.
remove body molding from pass side, is already off drivers side.
Remove and clean whole interior, all in great shape, blue interior, 40/20/40 no tears, just dirty. dash is perfect.
rear wheel wells are starting but i dont care.
doing the 5 speed swap, drive it for a few months, and sell it when my diesel bronco is finished this fall,
although my uncle tells me I'm gonna end up keeping this truck, but who knows
Hope to make a little money off it while letting it serve me through winter till the bronco is done.
Here are some pics.
ordering my valiar clutch today or tomorrow, any suggestions where to order through for best prices?
already hauled a cummins too lol
and a few of my 97 and the 84 that dont drive in the winter
me and uncle built both in the past 3 years. 84 is his, he bought it brand new when he was 18
1997 f250 4x4 sclb
When I bought it,
A LUK SMF
Here are some pics.
Nice beater there BIG...Good decision not to drive any truck that you are proud of in this rust belt thru the winter months!!
Your 97 RC is sweet!! I just bought a 96 RC 4x4 PSD with 104k original miles, 1 owner. Trying to get her picked up late next week!! What's your plans for the "diesel bronco"?
Thankyou, it was a labor of love.
That sounds awesome, what color? one ton?
I am building a 85 fullsize, 97 f350 axles, zf5 and transfer case, and a 94 p pump cummins motor.
but i wouldnt, considering a fresh 5 speed came with this one, id be stupid not to use it, especailly since this wont be a long term truck for me
Havent been updating. waiting on my rear driveshaft and ill be done with the swap.
I pulled the interior first, pressure washed and degreased the carpet, shampooed the seats, and degreased the panels.
Then pulled the auto and all associated parts, put manual parts on, and put trans in.
while trans was out we replaced the up pipe bolts, they were THIN
Got interior back together, need tog et a pic of the clean carpet, it cleaned up very well.
got my gooseneck mirrors on, bed rail covers.
did the 6637 filter.
got my chip reburned for my 5 speed.
replaced both batteries
will get more pics this week when its completely done
turning out pretty good
completely finished with the swap, need to clean up the bumpers, and going to buff and wax the truck, also probably going to replace the painted bezels and grill;e with a chrome set i have in great shape off my other truck
here are more pics
Got the new front tank in from a psd i parted out awhile back, ratchet straps always help when friends arent around
Mine and my uncles 7.3s, his are both 550 4x4 7.3 6 speeds. the 02 crew cab in the back has 35k on it, the tow truck is a 00 with 120k and mine has 220k
here are more pics
