Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
97 powerstroke SCLB freshen up and zf swap
Old 02-26-2015, 08:31 AM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
Bought this truck a month and a half ago.
Was too good of a deal to me for me to pass up, Plus i kinda liked it
bought it as a beater truck. all my trucks have been to nice and i worry alot. I absolutely love having a beater truck now!
1997 f250 4x4 sclb
7.3 e4od canadian built truck
220k miles
When I bought it,
Neweer injectors, runs like a top.
e4od isnt factory one, has been replaced somewhere down the line. already sold it for 500
Wheels and tires came with receipts, warranty, only had 400 miles on them. 315/75/r16s
Came with a FULL zf5 speed swap with a fresh zf5 less than 5k miles on it out of a f-superduty.
A LUK SMF
Manual PCM, adapter plate, bell housing bolts, pedals, full cluster, full column(neither of these I needed, just the PRNDL blank cover) Crossmember, t case linkage, clutch and slave cylinder.Shifter, shifter boot, literally everything but a rear driveshaft.
came with a used clutch but i will be putting a valair in it.
Truck needs some odds and ends. alot of parts i have sitting around already,
front tank leaks, but i have one for it from a cc psd i parted out.
install pass side step, its sitting in the bed with the piece of angle to reinforce it.
am putting the bigger mirrors on it, The "gooseneck" ones.
drivers side door hinges and striker
Probably glow plugs, havent diagnosed.
I plan on continuing to drive this through winter, to keep my green 97 off the road, I built that in 2013.
gonna buff and wax it. Was tu tone with light blue on bottom. PO didnt like it. bed-liner is only hiding rust on drivers side fender, everything else is solid and wasn't bubbling, i know this because it was a friend of mine that bought it and bed lined the bottom, so i saw it when it was tu tone.
remove body molding from pass side, is already off drivers side.
Remove and clean whole interior, all in great shape, blue interior, 40/20/40 no tears, just dirty. dash is perfect.
rear wheel wells are starting but i dont care.
doing the 5 speed swap, drive it for a few months, and sell it when my diesel bronco is finished this fall,
although my uncle tells me I'm gonna end up keeping this truck, but who knows
Hope to make a little money off it while letting it serve me through winter till the bronco is done.
Here are some pics.
ordering my valiar clutch today or tomorrow, any suggestions where to order through for best prices?
already hauled a cummins too lol
Click the image to open in full size.
and a few of my 97 and the 84 that dont drive in the winter
me and uncle built both in the past 3 years. 84 is his, he bought it brand new when he was 18
__________________
Matt
97 f350 reg cab long bed
4x4 460 ZF5
315/75/16 BFG MT KM2
Built Not Bought
Old 02-26-2015, 12:50 PM
dieselsubmariner's Avatar
dieselsubmariner dieselsubmariner is offline
dieselsubmariner is starting off with a positive reputation.
I bought my valair clutch of ebay . Had a really good deal . Just one word of caution: the Luk flywheel is different from the valair flywheel . I did a post on this about 1 month ago. Have. Look at it .
Btw nice Truck :-)
Old 02-26-2015, 02:31 PM
Quote:
Btw nice Truck :-)
THankyou!
I checked it out,
looks like you bought a valeo clutch and not a valair? did i read that right?
when i ordered my clutch earlier today, it asked brand of flywheel and LUK was an option so I chose it
__________________
Matt
4x4 460 ZF5
Built Not Bought
Old 04-08-2015, 09:29 PM
Havent been updating. waiting on my rear driveshaft and ill be done with the swap.
I pulled the interior first, pressure washed and degreased the carpet, shampooed the seats, and degreased the panels.
Then pulled the auto and all associated parts, put manual parts on, and put trans in.
while trans was out we replaced the up pipe bolts, they were THIN
Got interior back together, need tog et a pic of the clean carpet, it cleaned up very well.
got my gooseneck mirrors on, bed rail covers.
did the 6637 filter.
got my chip reburned for my 5 speed.
replaced both batteries
will get more pics this week when its completely done
turning out pretty good
__________________
Matt
4x4 460 ZF5
Built Not Bought
Old 04-08-2015, 10:29 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.ReBilld has a great reputation on FTE.
Looking good!
__________________
Bill
'95 F350 CCLB 4x4 dually,ZF 5spd,4.10,Rosewood Stage 2s,T500,S366,IC,Tony Wildman tunes,e-fuel,6637,CCV mod,3.5" DP,Diamond Eye 5" exhaust,Valair clutch,IH water pump,Scangauge,GlowShift gauges
Old 04-08-2015, 11:17 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is gaining momentum as a positive member of FTE.
Now that is how you clean up an old truck! Nice work. I thought I was the only one who disassembled interiors and degreased carpets and panels. You must be my brother! LOL Nice truck man!
Old 04-08-2015, 11:29 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE is gaining momentum as a positive member of FTE.MOOSE_MACHINE is gaining momentum as a positive member of FTE.
Quote:
looks good.
__________________
Sometimes your the windshield, sometimes your the bug
1997 F-350 xlt cclb PSD 4x4 zf5, 160/80's, custom tunes, T500, DIY e-fuel, 6.0 i/c, 38R, 3" plenums, gauges, 4" turbo back exhaust, diy bellows, south bend clutch
1992 F-250 2wd eclb 5.8 farm truck
1989 F-350 4x4 7.3 c6 auto retiread
Nick
Old 04-09-2015, 06:43 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
That's looking really good, Matt. Keep up the good work.
It's nice having a nice, shiny truck, but there is definitely something special about having one that you're not afraid to use and get a few scratches on.
__________________
--Nate "Just a redneck geek"
1997 F-350 7.3 PSD, 4x4, CCLB SRW, 3.55's, ZF5
If it isn't under warranty, I'll fix it myself.
Old 04-09-2015, 08:02 AM
What did you use as a degreaser for the carpet?
__________________
Nick
Old 04-09-2015, 08:09 AM
helifixer's Avatar
helifixer helifixer is offline
helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.helifixer has a spectacular reputation.
what are your plans for the auto pcm?
I need one but don't like buying them from a junk yard.
__________________
They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO
Diamond K your complete automotive and truck repair center
Old 04-09-2015, 09:26 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Purple Power is what I used to clean my carpet. I was going to buy new but mine came pretty clean.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,DI IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
Old 04-12-2015, 05:53 PM
Quote:
Originally Posted by ReBilld View Post
Looking good!
Thanlyou!
lol i love a clean interior, and whenever i buy an old truck i do this, I hate sitting in other peoples filth
Quote:
Originally Posted by MOOSE_MACHINE View Post
looks good.
thankyou!
thanks! really growing to like this truck
I used krud Kutter, worked really well
alrewady sold it, sorry!
Quote:
mine cleaned up great too
__________________
Matt
4x4 460 ZF5
Built Not Bought
Old 04-12-2015, 05:59 PM
completely finished with the swap, need to clean up the bumpers, and going to buff and wax the truck, also probably going to replace the painted bezels and grill;e with a chrome set i have in great shape off my other truck
here are more pics
Got the new front tank in from a psd i parted out awhile back, ratchet straps always help when friends arent around
Mine and my uncles 7.3s, his are both 550 4x4 7.3 6 speeds. the 02 crew cab in the back has 35k on it, the tow truck is a 00 with 120k and mine has 220k
__________________
Matt
4x4 460 ZF5
Built Not Bought
Old Yesterday, 10:21 PM
spent some time on the beater this weekend.
Wet sanded, buffed, polished and waxed the truck.
very happy with the results, color looks amazing
switched out the stupid painted black bezels and grille for a nice set of chrome I had. looks completely different.
__________________
Matt
4x4 460 ZF5
Built Not Bought
Similar Threads
OT: Ford Barn ZOOT 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 04-07-2015 02:50 PM
1985 bronco build and swap BiGGreen350 1978 - 1996 Big Bronco 34 03-16-2015 08:35 PM
1985 Bronco build BiGGreen350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 26 03-16-2015 08:27 PM
87-91 dash and radio bezel xlt eddie bauer bronco BiGGreen350 Ford Truck Parts for Sale 7 12-17-2014 09:46 AM
Everything look alright down there (rust, leaks)? loudoun 1999 - 2003 7.3L Power Stroke Diesel 3 07-16-2014 12:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
