Rear AC / heater controls
Old 02-26-2015, 08:31 AM
BMitch's Avatar
BMitch
BMitch is offline
The rear ac controls DONT seam to work. Ac works fine for the front, but when I try to control rear Ac from from front controls or the rear controls nothing happens. Heat or ac. Nothing comes out of the vents. Thoughts?
Old 02-26-2015, 09:14 AM
hasteranger's Avatar
hasteranger
hasteranger is offline
For the rear controls to work, the front has to be set to "rear" maybe obvious but thought I'd point it out. Should work from the front though.
Old 02-27-2015, 06:43 AM
wakeupluis's Avatar
wakeupluis
wakeupluis is offline
Mine was acting up. It was both of my blend door actuators where bad. I ordered them from Orielys auto parts. They where a special order item. Do not know if that is he same issue you are having or not. It was really easy to get the blend door actuators off. Just had to pull the passenger side rear panel off
AMCHARRIS
09-12-2021 03:06 PM
ducky
06-11-2008 07:39 PM
Five0guy
06-08-2005 09:54 PM
stvokc8885
11-22-2002 09:10 PM
Quick Reply: Rear AC / heater controls
