Little help please
Little help please
I want to change the 3.55 gear in my truck to 4.10. I see Summit has a Ford Racing ring and pinion set for $154. I would also like to buy a "kit" that includes everything needed for the change. Summit doesn't seem to have one for my application. Anybody know where to get a kit? Also, I'm toying with performing the install myself but need either encouragement or admonishment for considering this. I do all my own work and have for years, but have never set up a dif. I don't mind buying a couple specialty tools to do the job and if I have good instruction I feel like I can succeed just fine. But first I'm going to scour the local junkyards and if I can find one for a good price I will probably just replace the entire rear end instead. From what I've read I should be looking for a H5 axle code which translates to a 8.8" with 4.10 gear. Mine is a H9. Does that sound right?
Install kits on Summit http://www.summitracing.com/search/d...ng&keyword=8.8
Comfortable pulling/pressing bearings? Up for buying an inch pound non-click torque wrench, if so you can likely do it yourself.
Good luck finding a 4.10 8.8 you'll need it.
Jump out to Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale They are great to work with and know what you will need to complete your project. They also have some of the extras to help strengthen things up.
chrissims4463
08-10-2011 02:14 AM
A1C DiMaggio
19
04-10-2010 07:03 PM
spacednow
05-20-2006 04:41 AM
