Front Leaf Springs?
Front Leaf Springs?
My cousin has an 01 f350 crew cab dually 4x4.
One of his front leafs snapped in half.
Who makes good replacement front leafs that arent crazy expensive?
Any good heavy duty replacement leafs I should look into? Also do they bolt into hangers that are welded onto the truck or are they the standard pop riveted on hangers? Considering I've never seen the truck should I buy new hangers as well?
Thanks!
Thanks!
This is where I bought <table align="right" class="vi-VR-marTop5 "><tbody><tr><td>
</td><td>| Add to watch list
</td></tr></tbody></table>the ones for my 03 7.3
1999-2004 Ford Pickup Front Leaf Spring (2 Leaves)
Seller : sdtrucksprings
And they have bin grate. I hope link works if not I will retry.
Thanks for the link it worked. I have a question. I'm looking at my door jamb.
For my front GAWR it says 5200 pounds.
Does this mean that each spring should have a rating of 5200 pounds or does this mean that each spring should have at least half of that if not more?
The only place I have gotten replacement springs from is my local dealership. I have read good things about Deaver springs but do not know anyone who has them.
Here's the actual sticker.
On the truck the spring code is "VC". I found a spring code online but it's listed for just a "V" code. What's the differrence? There's two leaves in the pack and they're $180 each.
Here's a link to them. Will these work?
http://www.sdtrucksprings.com/index....54e3a30df68649
If you need replacement V codes or basically any other front springs let me know, I can supply you with new springs and hardware for a discounted price because you're a forum member.
Send me a PM.
-Junior
Send me a PM.
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
www.ATSsprings.com
Genuine 'V' or 'X' code springs can only be obtained from Ford. Aftermarket springs are not the same and will not have the same spring ratings. I have what are called 'X' spring aftermarkets but they do not have the same rating as Ford's 'X' springs do. These are the common 43-818 spring and I am happy with them. I got my rear springs from ATS and I am very happy with the springs and that company. You tell them what you want your truck to do and they will fit you a spring to match those needs. They will also be able to tell you what you need for shackles, bolts, etc.
The mounts are also a PITA to put back on as there's very liitle room to maneuver. Whatever you do DO NOT remove both lower radiator supports at the same time as your radiator will not be supported.
Received 3,101 Likes
on
That's what i did. Ordered springs from Junior at ATS. Paid him at 330pm Thursday, springs were at my house by noon Friday. Would buy springs from him again without even thinking twice about it.
After googling around and reading a bunch of threads i realized that most people take the front bumper off. I figured it was going to be a bunch of bolts holding it on. Turns out it was only 6 and the whole thing came off. Was totally straight forward after that.
To deal with the bolt being too long to get by the radiator mount i just pushed it out as far as i could, cut the bolt with an angle grinder, then air hammered the rest of the bolt out. Put the new bolt in with the nut facing the radiator support and that whole situation was dealt with.
Trucks all back together again and riding smooth. After driving this thing around for the night it totally makes me want to go buy one. They're awesome.
on
