Where can I get them for a reasonable price or is there a way I can get a gauge that will work with the 81 sending units because they ar like $30 cheeper and I would not have to change tanks
Well first off, what configuration is your 87 sender? is it an EFI model, electric fuel pump on sender, or one of the extremely hard to find engine mounted fuel pump and two prong connector models? there is no way to make the 87 gauge work with the 86 and older resistance values. The 87 sender is calibrated to work with the new style resistance values.
Just curious, why did you swap clusters like that?
THere was nothing wrong with the original cluster the 87 had a tack so I wanted to chang it out and then when I was having problems with the fuel gauge I took the one out of the 81 cluster to see if I could make it work and I broke the gauge
Honestly, I would just go to a junk yard and find a cluster with a factory tach for your year model. I just went to the JY last weekend and saw about 6 of these trucks, 2 had a tach cluster.
