08 F350 6.4 Code P0088
Ok need some help, replaced HPFP 38,000 miles ago. Truck began going in limp mode without engine light, wrench came on in dash, gave codes for brake switch, anti-theft, some other weird codes. Had those codes cleared, ran for while then water separator came on, drained the water out, came back on. Read some forums, so I removed and cleaned the housing, cleaned off the sensor. Had code cleared and ran good for about a week. Then guess what engine light comes on, limp mode. Went to Auto Zone, pulled code P0088. This truck runs awesome until limp mode. No other problems. I take it to the ford dealer, scanner pulled P0088 and the water separator code again. I have read alot of remarks about this P0088 code. Can there be another cause for pulling this code, only 38,000 miles later. I had them do the TSB 12-07-07 but I have also read it can only be done if the P0088 is the only code. Please advise, my bill is up to $4500.00. I just really feel there is an underlying issue with these 6.4's. Thanks for any advise!!!
High Pressure Fuel Pump
I just found this on powerstroke dot org:
P0088 - Known problem on HPFP fuel pump. Ford released TSB and updated "B" suffix pump to fix.
Here is TSB
TSB 11-4-22 6.4L - LACKS POWER - DTC P0088
Publication Date: April 27, 2011
FORD: 2008-2010 F-250, F-350, F-450, F-550
This article supersedes TSB 11-4-15 to update the Service Labor Time Standards.
ISSUE:
Some F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit a lack of power concern with an intermittent diagnostic trouble code (DTC) P0088; at full operating temperature during moderate to heavy acceleration.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Intermittent P0088 diagnostics:
1.) Check all continuous memory DTCs. Is DTC P0088 the only code present?
No - do not continue with this procedure. Refer to the Powertrain Control/Emission Diagnostics (PC/ED) to diagnose this concern.
Yes - continue to Step 2
2.) Replace the high pressure pump (HPP). Refer to Workshop Manual (WSM), Section 303-04C for HPP replacement.
Both the fuel volume control valve (VCV) and fuel pressure control valve (PCV) adaptive learning parameters must be reset after a HPP replacement. Refer to PC/ED, Section 4, Hard Start/No Start Diagnostic Subroutines step 7 to reset adaptive tables.
PART NUMBER PART NAME
8C3Z-9A543-B High Pressure Fuel Pump
OTHER APPLICABLE ARTICLES:
10-20-10
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110422A 2008-2010 F-Super Duty 6.4L Regular Cab: Check DTCs And Replace the HPP Includes Time For Prior Approval, Remove And Install Cab, And Reset Both VCV And PCV Adaptive Learning (Do Not Use with Any Other Labor Operation Except For Other Applicable TSB Articles) 8.9 Hrs.
110422A 2008-2010 F-Super Duty 6.4L Super And Crew Cab: Check DTCs And Replace the HPP Includes Time For Prior Approval, Remove And Install Cab, And Reset Both VCV And PCV Adaptive Learning (Do Not Use with Any Other Labor Operation Except For Other Applicable TSB Articles) 9.1 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A543 42
Good Luck!
Here is TSB
ISSUE:
ACTION:
SERVICE PROCEDURE
10-20-10
WARRANTY STATUS:
DEALER CODING
9A543 42
Good Luck!
P0088
So I've read alot about this fuel pressure to high at the rail code and can't find my answer. .....I live in Iowa and my truck will run fine all winter no codes then come spring and summer and I have done this for a couple yrs now 60-70 degree outside Temps and it starts throwing the code.....any ideas thanks
CPTMidnight
6.7L Power Stroke Diesel
18
05-16-2019 05:17 AM
