Which Tuner to use?
Which Tuner to use?
Hey Guys,
I need some help. MY 2000 6.8 is going to be the mule pulling my new Rockwood 8327ss.It will be in around April 20th and will be around 9500# loaded. I have 212,000 and everything seems ok right now and it runs great, but I would just to have a little more HP / Torque and higher shift points. I do not want anything to push the limits too far. Im adding the 6.0 Tranny cooler and I have 4.30 gears.So any insight or suggestions would be great thanks. Oh btw I have a Flowmasters and K & N filter on it already.
2000 Ex-cursion, Did you see a big difference when you added the flowmaster and the K&N filter? Which FM do you have? Is it loud inside the cab? I am looking to do that to my 2003 with less than 60k on it. Really nervous about it though. Congrats on the new rig even though it has been a year plus. Lol! Thanks Man. Jusbatty
on
2000 Ex, my X does great pulling my 9200lb TT. I took a trip to Disney one year and hitting any type of incline would drop the truck out of O/D this was constant unless I locked out O/D. after that trip I knew I needed some type of tuner just for fixing the poor shift programming Ford put in these things. the tuner made huge improvements in how it drives with the trailer. I can now hit any type of incline without it dropping out of O/D. it takes quite a bit of an incline/grade to get it to drop to third. so much more relaxing, I wish I would`ve done the tuner years ago, I`ve had it now for 3 years, money well spent!
No, I still have the stock springs with the Air Lift 1000 bags. I went with the 1000`s because I had them previously and they attach to the front of the axle on the spring. this helps load the spring which reduces spring wrap. the X specific bags go between the axle and frame. when aired up under load they will unload the springs and this in turn will cause increased axle wrap.
jusbatty, I have the big block Flowmaster. I m not for sure what number it is but I personally do not think it is too loud. The wife snarls everyonce in awhile lol. The overall seat of the pants feel is not much different other than I feel like it breathes a little better when I am really on it. As far as mileage I have not a clue, not much used on checking it, I know its not going to be good lol.
I am also a huge 5Star Tuning fan, as 1 EX Camper said it made a very good improvement in hill climbing while towing, much better shift schedule in the Tow/Performance tunes than stock. If your EX has one of the factory T shaped "Y" pipes then I also agree to get the upgraded Y pipe from 5Star along with the tuner. Be sure to fill out their calibration request form so they can take your other mods into consideration when writing your custom tunes. With how I drive I have found that I get better results using the 87 and 89 Octane Performance tunes while towing than I do using the Tow tunes, but part of that is my driving style, always with an eye on MPGs. I think the tow tunes would work better for the guys trying to get to the top of the hill first.
Our TT is 41' and 11k and my combination of 4.88 gears and 35" tires nets me an effective ratio of 4.39 so I think your 4.30s should serve you well with that 9k TT. Be sure to invest in a high quality WD hitch setup and take your time to get it dialed in correctly, makes towing so much more comfortable and safe!
WOW!! WE3ZS I was thinking I might be pushing the limit a little on Hp and Tq with my unit. I am now relieved seeing another EX'er pulling a larger unit than mine. I am very conserative when driving for the most part but every once in awhile its nice to open it up a bit and let her stretch her legs. What do you suggest when getting a new W/D hitch.How far have you pulled your unit? Thanks for all of the info and input!!
Your hitch purchase will have to be based on your budget and research, there a are a lot of options out there from El Cheapo junk all the way up to Pro-Prides and Hensleys. I use a Hensley Arrow sway elimination WD hitch with 1400lb spring bars, very similar to the slightly less pricey (when buying new) Pro-Pride, very high quality top end hitches. Then you have the Dual Cams and other units with built in sway control, with the size trailer you are looking at I would recommend something at this level or better. Do not go for the cheaper units with the friction based slide bar style sway bar(s), today's longer trailers need more than they can give.
I found my Hensley Arrow used on craigslist for $650, I repainted it and replaced 2 of the bearings and all 4 seals, looks and works like new!
We are based just outside of Philly and have pulled on separate trips to Savannah GA, Charleston SC, Sunset Beach NC, Cave City KY & Smokey Mnts TN, Blacksburg VA, Abbington MD, Pittsburg PA, Watkins Glen NY, Cape Cod MA & Mystic CT, Freeport ME, and a swing through VT, NH and RI as well as several "local" trips around our tri-state area.
Between the SC and GA trips I installed Banks headers, along the same route (I-95 N/S) the extra power from the headers allowed more time in OD and increased the towing MPGs by 1, and now with the tunes we have seen multiple pulls in the 8.5 to 9 MPG range with a best yet of 9.25 MPG on a run home from RI going around NYC. In stock trim with the 3.73 gears and stock sized tires (31.5") we saw averages of 6.5 to 7 MPG pulling our 9.5k toyhauler, the mods have been worth it to me!
This is my Hensley Arrow hitch shown on the old toyhauler.
This is the new longer heavier TT.
I also have a very similar setup to yours. I have a 7.3L, but the length and weight of the trailers are similar.
Have you done any modifications to the suspension? If not, I would put the tuner on hold and start putting together suspension upgrades because a stock Excursion is going to struggle with that load, handling wise.
I just finished doing all the work and my truck tows great now.
I bought one at the RV dealership. It ended up being $500 installed, but I'm very happy with the way it tows. It's a cheaper model but there is very little sway and the truck handles the load well. You can spend a ton more on the Hensley but depending on how much driving you do and your budget, I wouldn't judge anyone for staying with the more standard WD hitch/friction bar setup.
I've towed my RV twice - once home from the dealership, and another on a camping trip which was about a 7-8 hour drive each way. However, it was from sea level to 7600', back down to 5300' to camp, and over 7600' to get home. It was snowing at the top both times, but MUCH heavier the first time. They were making everyone put chains on but the guy let us through without them. I think he screwed up but, again, the truck did great.
Fastlane1
Computer Chips & Tuners
08-05-2005 02:21 AM
