Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
03 f250 with the 7.3L
Old 02-23-2015, 11:06 PM
dustingoss88 dustingoss88 is offline
dustingoss88 is starting off with a positive reputation.
I start it up and drive down the road and when i stop at a light or stop sign my truck will not accelerate and it losses power
Old 02-23-2015, 11:21 PM
RichardinVirginia RichardinVirginia is offline
RichardinVirginia is starting off with a positive reputation.
Need to know more...
Quote:
That is not a lot to go on. Right off I would be checking the two main things needed. Unrestricted fuel supply and unrestricted air flow.
Check filtering of fuel and filtering of air. Are the filters changed on a regular basis?
How many miles on the truck, how long have you owned it what have you repaired or replaced on it. Have you done any major modifications? Etc.
Old 02-23-2015, 11:25 PM
The truck has 256000 miles i have changed the air filter and fuel filter i have owened the truck for two weeks the turbo gets really hot. It has a power cip that the previous owner put in and i dont know what elts he has done
Old 02-23-2015, 11:36 PM
perhaps previous owner can help u?
The truck has 256000 miles i have changed the air filter and fuel filter i have owned the truck for two weeks the turbo gets really hot. It has a power cip that the previous owner put in and I don't know what else he has done
Is there any way to check fuel pressure (and or flow?).
My 2001 7.3 Turbo is pretty stock. I am sorry, I don't know much about chip packages.
If there is anyway you can ask the previous owner about this? -- that is where I would start.
By the way there is a lot of help on the internet. Lots of You Tube stuff and the like. I learned a lot from forums like this and from research. It takes time but it also saves you thousands of dollars over having to take it to a garage --- they love to see a diesel come in because they can overcharge you at will!
Wish I could be more help. But do the research and be patient.
If the fuel pressure is low, you then can diagnose the fuel pressure pump, the fuel lines, and the fuel tank for probable causes.
Good luck God bless America!
Old 02-23-2015, 11:42 PM
I took the power chip out so its just stock now i think but i was told the turbo should not get hot and if it das that means there is something wrong with the intercooler. Is this ccorrect.
Old 02-24-2015, 12:26 AM
Hmmm not sure, if that is the issue warning they are not cheap!
Old 02-24-2015, 12:29 AM
The main purpose of a powerstroke intercooler is to cool the turbocharger compressor discharge air. Front-mount intercoolers are typically installed behind your vehicle's grille, and it routes the discharge air through a high-efficiency heat exchanger core. This allows for a lower exhaust temperature as well as an extended engine life for your vehicle. These units are typically designed to fit specific vehicles, but a universal intercooler is designed to work with many different vehicle makes and models. Universal kits can include aluminum pipes, silicone hoses, and stainless steel clamps required for a complete installation. Sizes vary, but many intercoolers measure around 28 inches by 6 inches by 2.5 inches to easily fit behind your vehicle's grille. A powerstroke intercooler allows for better fuel efficiency and increased power. With the large inventory on eBay, you can find the right size unit for your vehicle.
Old 02-24-2015, 12:40 AM
You are new to the 7.3 diesel... are you SURE there is an inter cooler ?
Mine does not have one.
Old 02-24-2015, 08:39 AM
I looked at it and yes it has a intercooler i really dont know anything other the i have no power ones that turbo get hot
Old 02-24-2015, 08:47 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.thomabb has a great reputation on FTE.
I would expect the turbo to get hot, with the exhaust gasses routed through it. How hot? Glowing red hot? Do you hear metallic squeaks coming from it? Can you hear it spool up?
__________________
'02 F250 7.3 Auto Extended Cab Long Box 225+k Miles No Mods
Old 02-24-2015, 08:52 AM
It sounds like it spools but not like it should and im getting alot of white and gray smoke no black
Old 02-24-2015, 09:16 AM
thomabb's Avatar
You may have a boost leak. Not knowing much of the history of the truck, you are going to need to do some serious diagnostics. It is difficult to postulate with the amount of info you have. Is there a reputable diesel shop near you that would be willing to do a diagnostic? Maybe if you post your location someone in the brotherhood here that has the right scan tool may be close and willing to help for a six pack or two.
__________________
Old 02-24-2015, 08:18 PM
I live in freedom ny i took my truck over to brothers diesel and we think we might have figured it out we hope thanks for the ideas if u have more just keep writing them for me
Old 02-25-2015, 10:27 AM
thomabb's Avatar
What does the diesel shop think it was??
__________________
Old 02-25-2015, 10:47 AM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
^^^^^^What he said. Let us know what they found out.
__________________
2008 F450, 6.4 133,000 miles, utility bed /e99 F-350 Utility truck. 9' bed. swamp tunes, 6 speed. 353,000 miles /02 F-250, 4X4, PSD, CC, Auto, Swamps tunes, 147,000 miles
Join The Ky Chapter! http://www.ford-trucks.com/forums/forum151/ John
Similar Threads
Grinding Right Before Stop mblanken881 6.0L Power Stroke Diesel 9 09-24-2013 07:25 PM
motor shaking when stop ahmad Expedition & Navigator 10 02-20-2012 06:29 AM
Have to Push Hard on Brakes to Stop hudson Excursion - King of SUVs 8 06-02-2011 03:30 PM
truck dies while stopping Jayme Duty Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 04-26-2010 01:54 AM
brakes fordasouras Expedition & Navigator 1 11-03-2006 06:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
