HiPo cam in efi 302
HiPo cam in efi 302
Ok simple question, will this cam work with the EFI and ECU in my 1989 f150?
http://www.summitracing.com/parts/hr...ford/year/1988
I like the whole 600- 4800 rpm power band as right now 2nd gear has no power until you are going 60.
The motor is bone stock and has been for 170,00 miles, it has been taken good care of. Will it kill my motor and freak my ecu out? Or will it be a good cam?
on
Yes.. although the early trucks(pre '94) will benefit from a cam change too. You can find out what axle gearing your truck has by referencing the axle code found on the drivers door pillar to this table.. Ford Axle Code Chart - Ford Trucks
IMO anything less than 3.55 gears is unacceptable in a truck and if you have a trans with OD then 4.10 should be the minimum.
Correct...the vacuum level at idle starts to get lower and more pulsating with lower LSA. It's not impossible to overcome but it would require a custom tune. Plenty of cams, including this one IMHO, meet the standard criteria for Ford Speed Density based EFI, LSA needs to be 114 or higher. The duration at .050 looks good too.
on
Cam needs to have 114LSA and less than 210deg intake duration at 0.050" lift to be considered SD EFI friendly. Summit just relists whatever info they find for a part so if something isn't officially listed as being compatible they won't say it is... but that doesn't mean it isn't compatible.
