Removing bed bolts
Removing bed bolts
Need to remove my bed to install a utility body next week. I tried to loosen the bed bolts, broke 2 torx bits. My question is, can I just grind the bolt head off? get the bed off, then grind whats left of the bolt?
The reason i ask is because I tried this on my 1985 and the bolts were oddly shaped.
I had to grind the heads off two of the bed bolts on my 04'. The bolts seize fast to the captured nut clips that are on the frame. I used an angle grinder with a flap abrasive wheel and slowly worked it down trying to avoid digging into the bed itself. Worked pretty good. Once the head was off you can lift the bed straight up.
You might also want to try a Torx + bit since they are Torx + bolts. Torx + bits and bolts are a LOT better than standard Torx. Torx bits will sometimes work with Torx + bolts, but it is NOT a good fit and can easily break the bit if the bolt is tight.
You might want to double check for the size, but I believe that this is it:
Alternately, here is a set:
http://www.acument.com/products/comparison/
If you live in a salt zone forget about penetrating oil etc. ive removed four Ford beds ranging from 2000-2009 and no amount of PB Blaster, fluid film etc helped. Broke countless torx + bits and finally just removed the gas tanks and torched the bolts off. If your good with a torch you wont do any type of damage to the truck frame
iPhone from IB AutoGroup
Penetrating oil did not really do much on mine and like I said I still had to cut the heads off two. Over the course of a week they got drenched with penetrating oil half a dozen times or more. I even tried some heat on the stuck ones. After breaking half a dozen torx bits grinder came out.
The Torx bit size is too small and the bolts form the threads which gall easy and then they rust fast. Another bad design just to facilitate quick assembly at the plant.
I didn't even consider trying i just broke out the grinder, its faster IMO if you live up north to cut them and install new ones and potentially cheaper if you end up breaking a few bits and then have to buy a few bolts to replace the stuck ones. After looking i may have been able to get 2 out of the 8 out in the end and new bolts off Ebay are $40 sometimes.
Last year I was able to remove 2 bed bolts with penetrating oil and an impact. The rest were cut off with a standard plasma cutter.
These bolts were soaked with penetrating oil for several days before attempting to remove them. The stuff that they put on the roads now should be patented for its ability to weld steel parts together.
Lou Braun
Lou Braun
