Adding Posi/limited slip 95 f250
#31
Thanks again and again guys. I wanted the Detroit trutrac - but i got the LS for half the price used and with my budget it at least IS some improvement, the truck has pulled EVERYTHING i've ever put behind it - i just wanted "a little" more traction when i needed it i have spun front and rear tires on the dirt pulling wagons i should not pull 25k pounds, no tonge wait complete stop on a small hill you spin your tires on loose gravel, but it did pull it none the less..........
Only question i go threw a lot of mud pulling the wagons, - Will a LS kick in while im already moving 10-15 mph - meaning your not stuck yet oh crap its slowing down tires are spinning, but does the LS kick in at this point or only when you first take off
Edit don't forget to run friction modifier in your rear end now
#32
#33
Ill make sure i pick some up for this weekend!
Also from what i've been reading as long as i keep everything the same - i should be able to just swap carriers and not set the backlash or pinion.
I will check it, but can anyone verify that if i keep the shims same side the bearings all the same where they came of ect.
#37
While I know it's a redneck way, if you do not have a dial indicator with a magnet or visegrip base, you can still get it right if just swapping carriers. (not swapping gears or pinion bearings) The rule of thumb for backlash is to feel it, but not see it. It sounds crazy I know but grab the ring gear once it's all tight and rock it up and down. If you can feel the backlash but not see it, it's good.
Now before I get flamed, I know how to set up gears, have done it many times but many of the techs I worked with tested this theory many times and verified it with a dial indicator. It is always around .005-.007.
Ford spec is looser than this, but most shops shoot for .004-.009 or so.
#38
Installed a Detroit Truetrac in my F250 this past fall. BIG IMPROVMENT!!!
I pull a medium weight trailer 4000 to 7000lb. No more slipping one tire on wet roads when taking off.
As for the the install. I checked the backlash of the original (.013") before removal. Swapped my ring gear to the new carrier. Installed with factory shims in original positions and checked backlash again (.012"). Worked out great!
Todd
Todd
#39
You are correct. I should have said "turning under power".
Here are a couple of past discussions on this topic.
https://www.ford-trucks.com/forums/9...-truetrac.html
https://www.ford-trucks.com/forums/1...-truetrac.html
And that's what makes them terrible with farm-type trailers that weigh a lot but have zero tongue weight. Heavy trailers take a lot of force to move, but with zero tongue weight they don't help the tires hook up to provide that extra force. So the inside tire essentially never has enough traction (even on pavement) so it spins, making the locker lock.
try an aussie locker if all you use it for is towing. Ive heard from lots of guys they are very well built and never fail. And the installation is very simple. the only real complaint I have heard is they make a very audible ratcheting noise during turns but thats what you get with an automatic locker. They are very affordable as well.
That said, I'd agree that a lunchbox locker is the second-cheapest way to address the original problem of not being able to start up on a slightly slippery surface (locking the hubs is far and away the best cheap solution). A lunchbox locker (or a Detroit for more money) will give you the most help in that situation (better than a TrueTrac and far better than most clutch-type limited slips), but they will result in you spinning the inside tire on almost all powered turns, pavement or not.
#40
#41
While I agree that automatic lockers are poor to terrible for towing (and an incredibly terrible idea for towing heavy trailers with zero tongue weight), they do NOT lock "under power". They lock when one tire loses traction. Whether you are coasting or driving they will stay unlocked when turning unless you spin the inside tire (the only one being driven when it's unlocked
Detroit lockers are engaged when torque is applied to the differential ie hitting the gas
The only time they are unlocked is when you let off the gas pedal
The trutrac however will lock only when one tire starts spinning faster than the other the helical gears inside it slow down the faster spinning tire and apply torque to the slower or non spinning wheel
Clutch type ls only gives resistance to whichever tire is spinning to try and distribute torque to the other one imo not worth buying and wasting time putting them in
#42
Operation
During straight-line driving, the Detroit Locker captures 100% of available torque and sends it equally to both wheels. In turns and maneuvers, the internal components unlock to allow one wheel to spin faster or slower as necessary (free wheel). When the vehicle returns to a straight-line driving path, the components re-engage and provide power to both wheel ends.
No mention is made of "under power". They unlock "in turns and maneuvers" as I said.During straight-line driving, the Detroit Locker captures 100% of available torque and sends it equally to both wheels. In turns and maneuvers, the internal components unlock to allow one wheel to spin faster or slower as necessary (free wheel). When the vehicle returns to a straight-line driving path, the components re-engage and provide power to both wheel ends.
As I said above, that resistance is between the two sides of the axle. And although others do swear that they're useful and I won't say they're wrong, personally I agree with you and would never even bother rebuilding the one I have much less put one in.
#43
I don't have to check out the link I have a Detroit locker in one of my trucks yes it will unlock going around corners but you MUST let off the gas
You'll get one of two things with a Detroit locker when cornering either tires chirping or a ratcheting sound all depends on how you use the skinny pedal
#45
