1990 f250 low brake pedal
I have a 1990 f250 and the brakes have got progressively worse since I've owned it. Now the pedal goes all the way to about 1" from the floor. The truck still stops, but only the front brakes work. I know this due to when I'm on ice the rear tires slowly spin while I'm stopped. Could this be the rear drum shoes, and If so how do I check. Thanks
Received 3,102 Likes
on
You should take video of that then post it
Then try to adjust them I would take the drums off and inspect them first if they're worn pretty good might be time for new rear brakes
on
gotta use the parking brake religiously to keep them adjusted, and make sure the adjusters aren't old, crusty, or star wheel worn. also have to make sure the levers are not sticky, crusty, or seized.
its a good idea to have someone engage the parking brake with the wheel off to see if everything is working.
on
I've always had good stretches of good auto adjust time with fresh and lubed components. But yep, undeniable it doesn't last forever. Good idea to replace the adjusters and lube the arms every time a brake job is tackled.
rgnprof
15
07-13-2016 07:26 PM
