P0174 issues
P0174 issues
So im in search of some assistance. My 06 f250 has had bank 2 catalyst code ( p0430)and lean bank 2 code (p0174) only when i am trying to hard accelerate. It pops and jerks a little then takes off. So i hooked my scanner to it and found that the cat on bank 2 was bad watching pre and post cat o2 sensor readings. So i replaced the y pipe cat assembly And both downstream o2 sensors. I still get po174 on hard acceleration. If im light on it, it acts perfectly fine. Plugs were done a year ago along with one ignition coil.
Sounds like the typical cause of this DTC----vacuum leak most likely somewhere along the PCV valve plumbing.
Check at the base of the throttle body for the insulation-covered 90 degree elbow---they crack all too often. They're readily available from most any auto parts sellers, check with your local Advance Auto etc etc.
g3ride69
03-24-2016 05:56 PM
