replacing bearings in Dana 50 IFS
Also, what makes you think the pinion bearings are bad? Do you use 4wd a lot?
The big issue is the setting up. Proper pinion bearing preload is crucial.
The other fun part is with it on the bench holding it.
I use My trans holding fixture for 9" diffs. I would bet it would work for that as well.
It is not impossible but not a job just anyone can do...study the setup specs in a good manual.
PRIMERED79 SHORT BED
05-30-2018 02:42 PM
whdahel
1999 to 2016 Super Duty
12-08-2015 06:27 AM
$Simpleman76
07-18-2007 01:30 AM
