Code P0470 tube/sensor location
Old 02-21-2015, 07:42 PM
ZombiePopper's Avatar
ZombiePopper
ZombiePopper is offline
My truck is throwing the P0470 code (the only code, pretty common code), and I know that's a "Exhaust Backpressure Sensor Circuit Error", so I'd like to pull it and clean it out and the sensor as well.
I'm not sure what the tube is called but I haven't had any luck searching for P0470.
I'm wondering if anyone has a pic of it/its location, I've read it's around the AC comp. but there's a lot of tubes/hoses around there.
Thanks
Old 02-21-2015, 09:37 PM
greg_8507's Avatar
greg_8507
greg_8507 is offline
I don't have a picture, but if you look at your passenger side exhaust manifold you will see a metal tube coming from the front end of the manifold. Follow that tube to your EBPS, which is located by your HPOP(which is also close to your A/C compressor).
Old 02-21-2015, 09:50 PM
ZombiePopper
I'll take a good look around there thanks, gives me a good start point to trace it.
The HPOP is under the AC comp correct
Old 02-21-2015, 10:03 PM
greg_8507's Avatar
greg_8507
Standing in front of the truck it is next to the compressor on the right. The HPOP sits in the valley in front of the fuel filter housing. If i remember right the EBPS is on the left side of the HPOP reservoir(which sits on top of the HPOP), and hidden by a coolant line.
Old 02-22-2015, 01:29 AM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
Old 02-22-2015, 06:23 AM
whitetmw's Avatar
whitetmw
whitetmw is offline
Old 02-22-2015, 08:43 AM
ZombiePopper
Wow, perfect thanks guys!
Old 02-22-2015, 07:07 PM
DND58's Avatar
DND58
DND58 is offline
Trey put this up some time ago. Hope this helps.
Old 02-22-2015, 07:29 PM
ZombiePopper
Excellent vid,
Why no Tef tape though?
I would out of habit put Tef tape on the threads of the fittings, is it not necassary?
BIGRED 7.3L
02-27-2011 04:03 PM
erichy
01-08-2011 02:07 PM
jyblood
01-05-2009 05:30 PM
250turbo
03-27-2008 11:47 AM
pmasley
04-06-2006 10:13 PM
Quick Reply: Code P0470 tube/sensor location
