Wrong replacement battery
Today I bought what I thought was the correct battery for my 09 F150. When I got home, I noticed that the battery was a little bigger than the stock one. I looked up the battery on line and then saw that there is a Canadian version and American version. I don't know what that means, anyway the new battery is 750 Cold cranking amps and is bigger but fits in the battery box. The original battery calls for a 590 CCA and is smaller. Is this going to create a problem? Can I just use the bigger battery? Or should I get the right one? Both batteries are for 09 F150.
Cold weather is definitely a "double whammy", not only is the oil thick as molasses and current demands higher, at the same time the low temperature also reduces the current the battery is capable of producing through high internal resistance. It doesn't hurt anything to charge up a new battery prior to use, the last one I bought took 4 or 5 hours to reach full charge. This keeps the charging system happy. New batteries are also "hard" and don't reach full rated current capacity until a dozen or so starting and charge cycles.
In very cold weather, I also usually put one of my smart chargers onto the truck battery overnight. It's one of those things, you can't really tell if it helps, but it sure can't hurt. I do a lot of short trips around town in winter, and if the trip is short enough, your battery is probably ending the trip with less charge than it started. When it's -40, I want to know the truck will start.
I've had other vehicles with slow parasitic drains, and that's where this habit started from, but I keep it up, and it makes me happy for the five or six coldest nights of the year.
Just for fun, next time you are in a really cold spell, anything -20 and colder, put a voltage meter on your battery, then open the truck door and leave the interior lights on, and check that voltage again. It's a lot lower than you think. Even worse on my wifes mini-van with power sliding doors. Those door motors take a lot of juice.
LARIAT 85
29
05-30-2012 11:35 AM
