Bills Hunting truck
Bills Hunting truck
This is my beauty.. I hope you all like it.
The Admins will post a few pictures. Please be patient, I do not have permissions yet.
I'm Bill Rhinehart and I live in Riverside, Calif.
This is a BEAUTIFUL 1967 Ford F-250 Ranger Camper Special.
Turquoise over White.
2ND owner. 616,000 miles
Built 428 Cobra, Engle Cam, Hooker Headers, Holly 780, Pertronics ignition, Modified heads with hardened seats and valves. 470 HP. 500 Lb Ft. 12 MPG
Built C-6.
Dana 60 Limited Slip, 3.73 gears
PS, PB, Air, Cruise.
Sprayed in Bed Liner.
Those mirrors are FACTORY.
In near perfect shape. It's my hunting truck
It runs real well.
I'm excited to be here. I LOVE this truck.
I told my wife, "Honey, when I die you can sell everything I own, my trophy's, my guns, everything EXCEPT that truck. If you do, I'll haunt you from the grave."
Thanks
Bill
Built C-6.
It runs real well.
Thanks
Bill
Thanks
It turn heads and runs like a scalded ape. Eats up most anything that challenges it too.
It's hard to get it to"hook up". The limited slip just spins the rear tires if you don't take it easy.
Once it hooks up it's "Katie Bar The Door". Shift point 4900 RPM. Most times I just blow by the other and shut her down.
One thing that REALLY helped pep it up is the timing mod. I took the distributor out and re-set the mechanical timing to a max of 20 degrees then set the "initial" timing at 14 degrees. Now that big FE motor is super happy in the low end. (it HATES being set at 6 before) It doesn't heat up anymore and it's pulling 18.5 inches of vacuum at idle. (even with the cam)
on
The tires are 950 16.5's.
I'm not really interested in making it super street car.
It's a hunting and work truck.
Eventually I'm planning on getting rid of the 16.5's because finding tires is getting more difficult.
If I spend any money on it, I want another paint job and a Gear Vendors 2 speed overdrive. That way it'll get 15 or 16 MPG on the road. My friends 2010 Toyota 1/2 ton gets 14.
on
I drive easy too for the most part. But for some odd reason, my right foot just falls down once in a while, causing excessive noise and acceleration. It's an intermittent problem so I've never gotten a chance to diagnose it. Haha
O.O I could't even imagine the power behind that 428. Beautiful looking truck as well. Now when I see the Ranger burning its tires here in Riverside I know who it belongs too!
